Code help
rphillips
I have a list of blocks that i need to replace when there is one in the dwg file. Below is the code that i use to do that with but i would like to add to this.
My problem
When we receive files from our surveyor the blocks are repeated; example, if we have a block named X then it creates a new block for every occurrence (like so X_1, X_2, X_3) and so on. So the code below allows me to select all the blocks that have an X_ in the name and then it will replace with the correct name X. Currently I use the quick select command >block reference > Name > wilcard match > to search and find any block with an X_ in the name.
My Goal
For the code to do all the replaces using a list in the code.
I would like to add the search to the lisp and if no blocks in current file the just ignore.
the list would be something like
X_
APOINT_
MH_
FH_
I will compile the list in the code while testing.
then the code will replace name with name from another list
X
APOINT
MH
FH
and so.
Basicly I have a dwg with about 4000 blocks in it and it should only have abut 100.
X_1
X_2
X_1000
Should all be X
Thanks for the help
(DEFUN C:replace ()
(SETQ SS (SSGET))
(SETQ L 0)
(SETQ NB (GETSTRING "\nNEW BLOCK NAME TO REPLACE OLD:"))
(SETQ N (SSLENGTH SS))
(WHILE (
(SETQ E (ENTGET (SSNAME SS L)))
(SETQ E
(SUBST (CONS 2 NB)
(ASSOC 2 E)
E
(ENTMOD E)
(SETQ L (1+ L))
This should get you started. My lunch break is almost over so I can't do it all for you, but it'll help with the automation:
(mapcar '(lambda (x) (ssget "X" (list (cons 2 x)))) (list "X_*" "APOINT_*"))
That returns a list of selection sets, the first one being all blocks with a name that begins with "X_", and so on. You can make the list as long as you'd like.
Alls you need is to loop through and do something with each selection set, like a block replace.
Good luck, I'm sure you've got enough smarts to figure out the rest, if you've come so far already. ^.^
EDIT: And before anyone "corrects" me, yes, you could probably just extend the Lambda to include the block replace. I just don't have the time.
EDIT EDIT: Meh..
See if this works, it's untested. It'll insert the correct block at the same insertion point of the incorrect block, then delete the incorrect one. At least, that's the idea. My fingers are crossed.
(defun c:test( / ss entSet)
        (setq ss (ssget "X" (list (cons 2 (strcat x "_*")))))
        (if ss
        (setq entSet (vl-remove-if-not '(lambda (y) (= (type (cadr y)) 'ENAME)) (ssnamex ss)))
        (mapcar '(lambda (z) (vl-cmdf "-insert" x (cdr (assoc 10 (entget z))) "" "" "" "erase" z "")) entSet)
     (list "X" "APOINT"))
First of all thanks for the hlep!
This is what i get when running the code.
test ; error: bad argument type: lentityp (0
0)
0)
Yep, I know what went wrong.. forgot to mapcar a 'cadr to the vl-remove-if-not.
Try this:
        (if ss
        (setq entSet (mapcar 'cadr (vl-remove-if-not '(lambda (y) (= (type (cadr y)) 'ENAME)) (ssnamex ss))))
Thanks, I think that this works but i dont understand the code. This process takes to long there is about 4000 blocks and i belive this code has to repeat for every block.
This is what i am going to use
(setq SS (ssget "x" (list (cons 2 "X_*"))))
(if ss
(SETQ L 0)
(WHILE (
(SETQ E
(SUBST (CONS 2 "X")
(ASSOC 2 E)
E
(ENTMOD E)
(SETQ L (1+ L))
then i will repeat the code for to search for other blocks this seams to be a lot faster.
At the begining of my code i set cmdecho to 0 and then at the end i set it to 1 but for some reason when i do a purge it still list all the blocks deleted. Is there another way to get the command line not to repeat the info?
If you are substituting the Block Name, the alternative block definition must be in the drawing also.
The old block definitions will also still be in the database and will need to be purged.
(DEFUN C:RB ( / OriginalErrorHandling)
(vl-load-com)
(setq OriginalErrorHandling *error*)
(setq *error* ReplaceBlock_Error)
(setvar "cmdecho" 0)
(command "undo" "begin")
(command"ucs" "")
(if ss
(SETQ L 0)
(WHILE (
(SETQ E
(SUBST (CONS 2 "X")
(ASSOC 2 E)
E
(ENTMOD E)
(SETQ L (1+ L))
(setq SS (ssget "x" (list (cons 2 "APOINT_*"))))
(if ss
(SETQ L 0)
(WHILE (
(SETQ E
(SUBST (CONS 2 "APOINT")
(ASSOC 2 E)
E
(ENTMOD E)
(SETQ L (1+ L))
(command"-purge" "blocks" "" "no")
(command "ucs" "p")
(command "undo" "end")
(setvar "cmdecho" 1)
This is what i have so far
the lines in red are the lines that i wll have to change
the text in cyan is what will be changed in each line.
Does anyone see a better way to do this.
thanks
Sure it will work if i want to go and pick all the blocks.
Please read first post for more information.
Thanks for the help
I know the blocks will still be there that is why there is a purge at the end of the code. I just dont what the end user to see all the blocks being deleted.
