lulumara Posted August 27, 2009 Share Posted August 27, 2009 Hi, need to know how I can remove a two dimension I copy from other object , then when I grab it I can't pick it out and when I go to layout tab it doesn't show?? I'm using AutoCad 2006 . I did checked pickadd=1 is that value right? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2009 Share Posted August 27, 2009 If you just click on it (without running a command) what happens? Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 27, 2009 Share Posted August 27, 2009 Are all your layers on/ unfrozen etc...? Quote Link to comment Share on other sites More sharing options...
lulumara Posted August 27, 2009 Author Share Posted August 27, 2009 If I clikced the dimensions that I copied it doesn't pick up means i can't even touch it kinda weird? All the layers are not freeze. Only these two dimensions. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 27, 2009 Share Posted August 27, 2009 Have you tried purging and auditing? Can you post the drawing at all? Quote Link to comment Share on other sites More sharing options...
Tiger Posted August 27, 2009 Share Posted August 27, 2009 if you hit ctrl+A, do they get selected? have you tried closeing down the drawing and re-open it? Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted August 27, 2009 Share Posted August 27, 2009 Try QSAVE. Occasionally, I'll get a block of text that I can't select and QSAVE will bring it back. Quote Link to comment Share on other sites More sharing options...
lulumara Posted August 27, 2009 Author Share Posted August 27, 2009 Thanks to all who responds ,I did open the dwg dimensions were gone, Tiger your right. just close and open it. SuperCad I didn't have time to use the QSAVE because when I open it again it's totally gone. But anyways thanks to all again. Quote Link to comment Share on other sites More sharing options...
