shamkumaresan Posted August 30, 2009 Share Posted August 30, 2009 Dear friends, i am new to this forum. I want to replace file name in title block attribute with field (file name). i have to replace all iso's, p&id & ga's. Can any one post script for this... Block name : a3 tag : file Thanks in advance... Kumaresan Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 31, 2009 Share Posted August 31, 2009 Welcome to the CADTutor forum shamkumaresan. Let's see if I have this correct. You want to be able to replace a block attribute with a field? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 31, 2009 Share Posted August 31, 2009 All you need to do is filter out your title blocks and paste %% into the appropriate attribute in the properties dialogue. Quote Link to comment Share on other sites More sharing options...
shamkumaresan Posted September 2, 2009 Author Share Posted September 2, 2009 Hi Ronjon, i can do by double click on attribute and past with %% (since each file have only one title block) and save. but i want to reduce all steps into one single step. All you need to do is filter out your title blocks and paste %% into the appropriate attribute in the properties dialogue. Quote Link to comment Share on other sites More sharing options...
shamkumaresan Posted September 2, 2009 Author Share Posted September 2, 2009 Yes my friend, i want to replace more than 4000 files title block attribute with field (file name) Welcome to the CADTutor forum shamkumaresan. Let's see if I have this correct. You want to be able to replace a block attribute with a field? Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted September 2, 2009 Share Posted September 2, 2009 Sweet Mother McAuthor! Why not have the title block xref'd to your sheets? The attribute if setup properly will point to the right file. Quote Link to comment Share on other sites More sharing options...
shamkumaresan Posted September 2, 2009 Author Share Posted September 2, 2009 Hi Calvin, I think it will make more steps than by double clinking atribute & past %% then save file. Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 2, 2009 Share Posted September 2, 2009 Hi Calvin, I think it will make more steps than by double clinking atribute & past %% then save file. hardly, you will remove the need to do this in the future. Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted September 2, 2009 Share Posted September 2, 2009 hardly, you will remove the need to do this in the future. Correct. You will then only have one title sheet to deal with rather than 4000 sheet files with the title block inserted into each of them as a block. That is 3999 less steps to go through. Quote Link to comment Share on other sites More sharing options...
shamkumaresan Posted September 2, 2009 Author Share Posted September 2, 2009 Correct. You will then only have one title sheet to deal with rather than 4000 sheet files with the title block inserted into each of them as a block. That is 3999 less steps to go through. I like to update all the files like giving batch plot. (Because our company keeps separate file for each iso lines.) we are not using xref blocks or both model space & paper space in same file. thanks kumaresan Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted September 2, 2009 Share Posted September 2, 2009 I like to update all the files like giving batch plot.(Because our company keeps separate file for each iso lines.) we are not using xref blocks or both model space & paper space in same file. thanks kumaresan That seems very counter productive. Creates more work than is necessary. CAD was designed to help make our lives easier as drafter/designers not make it more complicated. Quote Link to comment Share on other sites More sharing options...
