Shibuboss Posted September 1, 2009 Share Posted September 1, 2009 Hello every body, Is there any option to convert "Circle" to polyline and give thickness. Usually i draw a circle and use polyline command and use " arc " to give thickness to the circle. I know that it's not the proper way. I want to use this thick circle for making viewport. Please advise. Thanks in advance. Regards_______ Quote Link to comment Share on other sites More sharing options...
NBC Posted September 1, 2009 Share Posted September 1, 2009 Another way would be to 'place' your circle and ensure it's lineweight (or the layer's lineweight that the circle is on) is set to your desired 'thickness' Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Thanks for your replay NBC Yes i know this method using layer give lineweight. There is no "direct" method? if so please advise.thank you Regards______ Quote Link to comment Share on other sites More sharing options...
eldon Posted September 1, 2009 Share Posted September 1, 2009 How about using Donut, with the inside and outside diameters chosen to give the desired thickness. A donut is also a polyline. Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Yes that's a good idea Elden.Thanks. Regards______ Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Oops.. Elden in layout i can't convert that "DONUT" object to viewport. I have to draw another circle to convert that in to viewport. Regards_______ Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 1, 2009 Share Posted September 1, 2009 Lisp routine for replacing a circle with a lightweight polyline. Use Pedit to assign thickness. http://www.autocadeverything.com/help/archive/index.php/t-2092.html Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Sir thanks a lot. Really this is the one i am looking for.thank you Regards_________ Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Sir same problem. It's not applicable for making viewport.please advise.thank you. Regards_______ Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 1, 2009 Share Posted September 1, 2009 Why would you need a viewport created with a circle that had thickness? Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 1, 2009 Author Share Posted September 1, 2009 Sir thanks for your replay. Whenever i arranged the details in layout with different type viewports.my boss advise me to give a thickness around the detail for easy reference and appearance. In circle viewport it's taking too much time.i thought that for this issue have a solution.that's why i post this thread. Anyway i am much happy with "Donut" command and the "Circle2pline" lisp.same effect in layout.thank you. Regards_______ Quote Link to comment Share on other sites More sharing options...
BILL WILLIAMS Posted September 1, 2009 Share Posted September 1, 2009 Try dotsoft and circle2pl.vlx Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted February 27, 2012 Share Posted February 27, 2012 Create a 4-sided polygon, using the POLYGON command. You can circumscribe or inscribe it. At the prompt for the radius, enter the radius of the circle that you want. Start the PEDIT command, select the polygon, and use the Fit option. Presto! You have a circle. Then use the Width option and specify the width that you want. Quote Link to comment Share on other sites More sharing options...
