I wouldn’t exactly say it is a definite but passing open database object references between sub/functions may not be the best practice. I modified the structure to illustrate an alternative. Note: Autodesk.AutoCAD.Geometry objects are not database residents
I think the reason that the Ray was not showing was because the top level transaction had not been committed. Again, I modified the routine to illustrate that point.
Code:
<CommandMethod("src")> _
Public Sub src()
Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim acBaza As Database = lCmd.Document.Database
Using trn As Transaction = acBaza.TransactionManager.StartTransaction
Dim lnL1 As Line = New Line()
Dim usrPtOp As PromptPointOptions = New PromptPointOptions("Wskarz srodek pomieszczenia :")
Dim usrPt As PromptPointResult = lCmd.GetPoint(usrPtOp)
Dim prevPt As Point3d = usrPt.Value
Dim nextPt As Point3d = usrPt.Value
If usrPt.Status = PromptStatus.OK Then
Dim usrPtXmod As Point3d = New Point3d(usrPt.Value.X + 1, usrPt.Value.Y, usrPt.Value.Z)
Dim ls3d As LineSegment3d = New LineSegment3d(usrPt.Value, usrPtXmod)
'FILTRACJA LINII
Dim typeValue() As TypedValue = {New TypedValue(0, "line")}
Dim selFilter As SelectionFilter = New SelectionFilter(typeValue)
Dim selResult As PromptSelectionResult = lCmd.SelectAll(selFilter)
Dim ssLinie As SelectionSet = selResult.Value
Dim tabID() As ObjectId = ssLinie.GetObjectIds
Dim oid As ObjectId
'TRANSAKCJA
oid = przecieciaPromienia(ls3d, tabID, prevPt, nextPt)
Dim lnNajblizsza As Line = CType(trn.GetObject(oid, OpenMode.ForRead), Line)
'Sprawdzenie ktury punkt jest nizej
Dim START As Point3d
'Dim FIN As Point3d
If lnNajblizsza.StartPoint.Y > lnNajblizsza.EndPoint.Y Then
START = lnNajblizsza.EndPoint
Else
START = lnNajblizsza.StartPoint
End If
End If
trn.Commit()
End Using
End Sub
Public Function przecieciaPromienia(ByRef ls3d As LineSegment3d, ByRef tabID() As ObjectId, ByRef prevPt As Point3d, ByRef nextPt As Point3d) As ObjectId
Dim acBaza As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim lnNajblizsza As Line = Nothing
Try
Dim btr As BlockTableRecord = CType(trn.GetObject(acBaza.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim objID As ObjectId
Dim ra3d As Ray3d = New Ray3d(ls3d.StartPoint, ls3d.EndPoint)
Dim odl As Single = 0.0
Dim odlTmp As Single = 0.0
For Each objID In tabID
Dim ln As Line = CType(trn.GetObject(objID, OpenMode.ForRead), Line)
Dim ls As LineSegment3d = New LineSegment3d(ln.StartPoint, ln.EndPoint)
Dim ptArray() As Point3d = ls.IntersectWith(ra3d)
If ptArray Is Nothing Then Continue For
Dim ptkPrzeciecia As Point3dCollection = New Point3dCollection(ptArray)
'SZUKANIE PIERWSZEJ NAJBLIZSZEJ LINII
' odl=sqrt ((x1-x2)*(x1-x2) + (y1-y2)*(y1-y2))
odlTmp = Math.Sqrt((prevPt.X - ptkPrzeciecia.Item(0).X) * (prevPt.X - ptkPrzeciecia.Item(0).X) + (prevPt.Y - ptkPrzeciecia.Item(0).Y) * (prevPt.Y - ptkPrzeciecia.Item(0).Y))
If odl = 0.0 Then
odl = odlTmp
nextPt = ptkPrzeciecia.Item(0)
ElseIf odl >= odlTmp Then
End If
lnNajblizsza = ln
Next
lnNajblizsza.Highlight()
Dim promienSledzacy As Ray = New Ray()
promienSledzacy.BasePoint = ls3d.StartPoint
promienSledzacy.SecondPoint = ls3d.EndPoint
promienSledzacy.SetDatabaseDefaults()
btr.AppendEntity(promienSledzacy)
trn.AddNewlyCreatedDBObject(promienSledzacy, True)
trn.Commit()
Catch ex As Exception
End Try
Return lnNajblizsza.ObjectId
End Using
End Function
