Results 1 to 4 of 4
    Junior Member
    AutoCAD 2007
    Jan 2009
    24
    Default Dimension problem
    Hi All,
    When I take a dimension on the drawing the result only shows up to 2 decimal places. How can I change it so my results are more accurate, I would like the result to be to 3 decimal places. (e.g ..151)
    Thanks in advance
    Mac.
    Junior Member
    AutoCAD 2010
    Aug 2009
    Holland
    22
    From the mene select Format>Dimension Style
    Select the current dimension style and click on modify.
    On the Primary Units tab select the drop-down box "Precision" and change it to 0.000
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,112
    check you dimension style|primary units|precision setting.
    there is a variable you can change to achieve the same result but its worth browsing the dimension style dialogue box to get familiar with what you can change.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    1. This one:
    Quote Originally Posted by JonathanP View Post
    or
    2. Setvar >> DIMDEC>> 3.
    We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself. ~Lloyd Alexander
  1. Dimension problem
    By dinarele in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Jul 2009, 05:01 pm
  2. Dimension problem???
    By taqr07 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2007, 07:57 pm
  3. Dimension Problem
    By djgraham20354 in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2006, 11:32 am
  4. Dimension>Style or Format>Dimension Style problem
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2004, 08:50 pm
  5. dimension problem
    By RichCT in forum AutoCAD Beginners' Area
    Last Post: 4th Apr 2004, 09:27 pm
