woodman78 Posted September 8, 2009 Share Posted September 8, 2009 I have created a dynamic block for a typical information note that I use on some of my layout drawings. The thing is I want to include a square on the left side that will remain centered, Vertically Only, when I stretch the block. I had been able to do this using a very basic test block but on this more complicated one I can't seem to get it to work. Could someone have a look and let me know if they spot anything. Thanks. Label with Info.dwg Quote Link to comment Share on other sites More sharing options...
dbroada Posted September 8, 2009 Share Posted September 8, 2009 I removed the point/move and replaced it with a single move action. I also removed the main hatch so I could see what was happening. Check your visibility states too as the square was only visible with the pointer in the TL corner. anyway, try this.... Incidentally, don't use "please help" for titles. I normally ignore such vague titles but more importantly it won't allow you to use the search facility. Label with Info 2.dwg Quote Link to comment Share on other sites More sharing options...
