Wouldn't you have to tell AutoCAD where to find the macro? Something along the lines of -vbarun"C:\Macros\mycustom_macro".
Hello there ,
I was searching all over the forum but i didnt find, how tu run load macro from command line automaticly.
if i use :
-vbarun
ask me for a name of macro when i tiped in its all Ok then RUn my macro.
but how can i use -vbarun in one line because i want to have shortcut in my button.
itried;:
-vbarun;macro_name didnt work
i hope u understend my problem.
I want to tipe command that execute macro in on line in command line. My macro it loaded in stratup suit.
thx
defun it to Lisp Command
(vl-load-com)
(defun c:ttx() (vla-runmacro (vlax-get-acad-object) "D:\Project.dvb!ThisDrawing.tt"))
I use the following syntax
I must note, however; that I put the above into a script file; and then create a toolbar button to open the script file.Code:-vbaload;"C:/AutoCAD/VBA/filename.dvb;-vbarun;"C:/AutoCAD/VBA/filename.dvb!macroname"
Life's constantly changing - keep up or get left behind
ok i tried i have acad 2009 map:
my file is located on :and i do this shortcut but dont work:HTML Code:C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb
-vbaload;"C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb;-vbarun;"C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb!izrniv"
macro is run with "izrniv"
where have i misted?
I have my routines in the ACAD.DVB file, and in that is a short module like this.....
then on my button I use this syntaxCode:Public Sub Cloud() Set myObject = New frm_Cloud myObject.Show Set myObject = Nothing End Sub
and all the code is embeded in frm_CloudCode:^C^Cvbastmt;cloud;
"That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
Dave
Thank u very much, i cant belive this actually works. I change direction of slash & works perfect, I new that is a simple solution for this.Code:Try changing the direction of the slashes e.g. from \ to /
thx to every one.
