Results 1 to 8 of 8
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Default Filter Polylines based on elevations
    Hi,
    I have a drawing with polylines representing Contours. All the polylines have elevations (10m intervals) and are on the same layer. I need to change the 50m contours to a different layer. So I want to be able to select all polylines on this layer with a elevations 50, 100, 150, 200 .....etc It is over a 200 km2 area
    I tried using filter but it did not work for me
    I based the filter on polyline, layer and elevations ie 50, 100 ......etc
    Has anyone any other ideas how to accomplish this?
    or what am I doing wrong with the Filter
    thanks
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Default solved
    thanks to anyone who took time to read the post.
    I have solved my issue myself using the filter command.
    If anyone wants the answer I will post it
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    The filter would look something like this to isolate polys by elevation.
    Edit: A few minutes too late
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    thanks that's exactly what I did, saves me posting the answer now.
    thanks
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    If you take a Front view, all the polylines are visible with each elevation separately. A visible filter
  6. #6
    Forum Newbie
    Environmental
    AutoCAD 2016
    Dec 2016
    2
    I would like to do the same thing. I set up the FILTER the same exact way with my desired input elevations. However, upon clicking "Apply", nothing is selected, and AutoCAD instructs me to select objects. When I attempt to select objects, nothing at all is selected. I have looked at quite a few other posts and can't seem to resolve it. The objects are labeled as 3D Polylines in the properties window. Any ideas?
    The process used is fairly long, so being able to select all of the major contours (10' increments) and apply them to one layer first would be helpful in streamlining the process.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    If you want say 10 then 20 then 30 and dont have a huge number of intervals then just sue Polyline and elevation in your fileter keep changing the elevation varaiable.
    Better way is do a search here its been answered before using a lisp. A post last week wanted colours to change via elevation.
  8. #8
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by ckaravan View Post
    Do 3D Polylines have Elevations?
    Untested, just seems unlikely, as the end points could be at different Z Values.
    Unlike regular Polylines which are flat, and thus at a single elevation.
    Off the top of my head, your filter might need to define Z values of end points instead of Elevation, in order to account for 3D Polylines.
    Using the CHANGE command on a set of non-horizontal 3D Polylines, and changing their elevations to 0, flattened them all out, so I guess they do have Elevations (probably defined by the Z Vertex), but not sure how to apply that information.
  1. select all polylines in the drawing based on its property using VBA
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jan 2009, 05:03 pm
  2. Autodesk 2D Browser based CAD
    By Xenophon in forum Autodesk Software General
    Last Post: 20th Dec 2008, 10:59 am
  3. Using "Filter" to filter out MText
    By kirkmactavish in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2007, 02:11 pm
  4. Replies: 0
    Last Post: 2nd Nov 2006, 11:51 pm
  5. How do i create an app online CAD based???
    By lua_roxita in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2006, 09:43 am
