Shortcut keys
DWG Destroyer
Something strange that I feel needs an answer to; when ctrl is held in AutoCAD, the crosshairs turn into a pick box, yet the pick box doesn’t seem to do anything. Is there something useful that this ctrl+click can be used for? I’d like to maybe hold ctrl and then click a blocked attribute to access the block editor quickly, rather than having to select it then click the block edit button… Any advice?
Yes, this is the situation, but what you have described leads me to opening the attribute editor box, not the block editor! I am aware I can change this via the double click settings in the CUI but what if I want both?? I'd like to keep it as it is, but when CTRL is held I’d like for it to open block editor instead of att edit.
