Results 1 to 8 of 8
    Full Member ORgrown's Avatar
    AutoCAD
    Apr 2005
    61
    Unhappy Publish Multi-sheet to PDF--to scale & 2 diff paper sizes
    Tried searches in CADTutor & internet & AutoCAD Help...
    AutoCAD 2010 (vanilla)
    Have DWGs with mulitple sheets: 2-NTS & 1-set to specific scales (each DWG may be different scale).
    Need to Publish to PDF the sheet set for 8-1/2x11 & for 11x17, keeping the set scale.
    When I attempt to publish, I can only get 11x17...
    Also, I get a warning each time I Plot or Publish:
    "Adobe PDF.pc3: This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted."
    Not sure if this latter warning has any affect on what I'm attempting, but I'm pretty sure I just don't know what the heck I'm doing...ultimately I need to learn how to correctly publish to two different paper sizes (to scale).
    Thanks, Everyone.
    ORgrown
    Super Member chulse's Avatar
    chulse's Computer Details
    Windows 7
    17" wide screen laptop w/ 22" acer
    See details...
    chulse's Discipline Details
    Senior Urban Forester
    See details below.
    Tree Preservation Planning for civil design and developent
    Civil 3D 2016
    Jul 2007
    Front Royal, Virginia
    1,320
    What PDF print driver are you using then (if the Adobe.pc3 is missing)?
    Do you have sparate "page setups" (in the Page Setup Manager) for each paper size you want?
    Cary Hulse
    Wetland Studies and Solutions
    AutoCAD
    Apr 2005
    61
    Cary,
    The "page setups" are named for the different page tabs. The setup is for 11x17, so I don't know how 8-1/2x11 PDFs were created initially (each DWG has 2-PDFs associated--11x17 & 8-1/2x11).
    Regarding what PDF print driver I'm using....have.no.clue...I'm publishing/printing PDFs by selecting DWG to PDF.pc3.
    New machine for me and programs were loaded by IT.
    ORgrown
    Windows 7
    See details...
    See details below.
    Civil 3D 2016
    Jul 2007
    1,320
    "DWG to PDF.pc3" is the driver you're using.
    You will need to create a page setup for the 8.5x11 page size and print using that. You already have the layout tab created for that page size, correct?
    Cary Hulse
  5. #5
    AutoCAD
    Apr 2005
    61
    There is only one layout tab for the complete drawing (titleblock) and it is set up for 11x17. When I received the DWG, it came with two PDFs--one at 11x17 and one at 8-1/2x11.
    ORgrown
  6. #6
    Windows 7
    See details...
    See details below.
    Civil 3D 2016
    Jul 2007
    1,320
    Ok,
    If I understand you correctly, I think this is what you are wanting to do. There are 2 page setups in this dwg - one for 11x17 and one for half scale (8.5x11). Take notice of the page scaling in the setups.
    www.thecareoftrees.com/chulse/test/half%20scale%20test.dwg
    Cary Hulse
  7. #7
    AutoCAD
    Apr 2005
    61
    Smile
    Very helpful, Cary.
    Thanks. My limited use of AutoCAD has limited my skills/knowledge as well. I don't typically set up scaled drawings and haven't done so for a lifetime...
    Thanks again.
    ORgrown
  8. #8
    Windows 7
    See details...
    See details below.
    Civil 3D 2016
    Jul 2007
    1,320
    So you got it to work then?
    Cary Hulse
  1. Sheet Sizes in IDW template
    By DVDM in forum Autodesk Inventor
    Last Post: 2nd Dec 2008, 12:41 pm
  2. Publish command in 2009 will not do multi-page PDFs
    By chulse in forum AutoCAD Drawing Management & Output
    Last Post: 12th Sep 2008, 11:36 am
  3. put two diff drawings with diff scale
    By ali888 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2006, 03:20 am
  4. US paper sizes
    By dbroada in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Feb 2006, 02:59 pm
  5. Replies: 1
    Last Post: 16th Aug 2005, 10:30 pm
