Results 1 to 4 of 4
    Junior Member
    not specified
    Dec 2004
    11
    Default REFEDIT - when add an attribute, it disappears once I save!
    Hi Everyone,
    I have a block with many attributes and want to add another attribute.
    So, I REFEDIT the block, create an attribute, add it to the block (and when I do it says it's already part of the working set, which is normal I think), and I save changes.
    The Problem: once I save...it disappears!
    When I try to add a text box, a circle, etc, to the block, no problem, it doesn't disappear.
    Any ideas?
    THanks for your help...
    Scott
    Win XP, Autocad 2004
    Senior Member
    not specified
    Sep 2005
    Brisbane, Australia
    318
    Check that you are not giving the new attribute tha same tagname as an existing attribute
    Regards,
    Eddie
    (Acad,ADT,AutoPLant Structural/Prosteel)
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort. "
    Senior Member Kate M's Avatar
    Structural
    Revit Structure 2013
    Sep 2003
    Washington, DC
    477
    You must ATTSYNC after making REFEDIT changes to block attributes.
    Junior Member
    not specified
    Dec 2004
    11
    Default ATTSYNC!
    Thank you both, ATTSYNC was the answer!
    Scott
