Results 1 to 8 of 8
    Super Member chrisdarmanin's Avatar
    AutoCAD 2009
    Feb 2006
    Malta
    524
    Default Simple lisp request please :)
    is it possible for someone to make me a lisp to invert the layer status? (on/off, frozen/thawed)
    what do you think? is it easy?
    many thanks in advance
    Quote by George (AWDC Malta President) about Land Rovers:
    "Trid ittiha xebgħa mazza ta' bla raġuni"
    Translation: You have to attack it with a mallet for no reason at all"
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,040
    Quote Originally Posted by chrisdarmanin View Post
    I'll be glad when this insomnia wears off, I'd like to go to bed.
    This is a fairly easy task to accomplish. Definitely something anyone could accomplish with a little work.
    Hope this helps. BTW, I think this can be accomplish in the layer manager, but I'm not sure, I never open it.
    Code:
    ;;; Invert on/off and freeze/thaw state of all layers in drawing
    ;;; Alan J. Thompson, 09.14.09
    (defun c:LayerInvert (/ #Doc)
      (vl-load-com)
      (vlax-for x (vla-get-Layers
                    (setq
                      #Doc (vla-get-activedocument (vlax-get-acad-object))
                    ) ;_ setq
                  ) ;_ vla-get-Layers
        ;; invert on/off state
        (vl-catch-all-apply
          'vla-put-layeron
          (list x
                (if (eq (vla-get-layeron x) :vlax-true)
                  :vlax-false
                  :vlax-true
                ) ;_ if
          ) ;_ list
        ) ;_ vl-catch-all-apply
        ;; invert freeze/thaw state
        (vl-catch-all-apply
          'vla-put-freeze
          (list x
                (if (eq (vla-get-freeze x) :vlax-true)
                  :vlax-false
                  :vlax-true
                ) ;_ if
          ) ;_ list
      ) ;_ vlax-for
      (vla-regen #Doc acActiveViewport)
    ) ;_ defun
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    AutoCAD 2009
    Feb 2006
    Malta
    524
    hmmm.... it doesnt seem to switch on those that are off......
    (because it needs to do that)
    Civil 3D 2011
    Apr 2008
    6,040
    Works fine for me. On->Off, Off->On, Frozen->Thawed, Thawed->Frozen
    I even tested it on a file that has 730 layers (some even xrefed) with all assorted states. Everything was completely successful.
  5. #5
    AutoCAD 2009
    Feb 2006
    Malta
    524
    i'll try again on another drawing later.... busy at work at the moment.... btw have you managed to get some sleep?
  6. #6
    Civil 3D 2011
    Apr 2008
    6,040
    Hope you get it to work. I'll give it another look tomorrow. Still no sleep, but I'm going to make another attempt at it.
  7. #7
    AutoCAD 2009
    Feb 2006
    Malta
    524
    i realised my problem now which is with my original question :S
    can you remove the part where it inverts the freeze/thawed state because i was letting everything thawed so it froze everything....
    my mistake sorry....
    thanks again for your help
  8. #8
    Civil 3D 2011
    Apr 2008
    6,040
    Easy fix, just remove this portion from the above code (I marked it in red):
    Code:
        (vl-catch-all-apply
          'vla-put-freeze
          (list x
                  :vlax-false
                  :vlax-true
                ) ;_ if
          ) ;_ list
  1. Lisp file request
    By Stryder in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Oct 2009, 09:40 pm
  2. Wall LISP Request.
    By TheNewGuy in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2009, 05:23 am
  3. LISP Request - Elevations
    By Bill Tillman in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Apr 2009, 04:25 pm
  4. A lisp request
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2007, 02:24 pm
  5. Request for Lisp
    By aledtaylor in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Dec 2005, 04:01 pm
