Beckyfonts Posted September 14, 2009 Share Posted September 14, 2009 This concerns mechanical drawing, for example the dimension is 350 mm and I want to set the tolerance to -2 mm only and not ± 2 mm, how should i do it? Sorry if this question seem too basic but I am new and needs help on this. Thanks. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted September 16, 2009 Share Posted September 16, 2009 In the PROPERTIES dialogue box there is a text override option which I think is what you're after? Quote Link to comment Share on other sites More sharing options...
Beckyfonts Posted September 16, 2009 Author Share Posted September 16, 2009 I will try as you suggested. Trying to explore things. Was able to do it using Limit as suggested by Dave. Thanks for your advice. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted September 16, 2009 Share Posted September 16, 2009 Hmmmm now I'm confused... Who's Dave... Edit: I guess you mean Limit option in the tolerance drop down of Properties? Quote Link to comment Share on other sites More sharing options...
