Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    Map 3D 2007
    Sep 2009
    142
    Default Commands vrom VLX in Lisp
    Hi
    I'm trying to run a command inside a lisp, that is loaded from a vlx file into autocad. But it gives me an unkown command error. If I simply run it from the command line it works, but not through a lisp. Do I need to do something extra for the command to be avaialable from a lisp? I don't have access to the source of the vlx.
    Senior Member
    not applicable
    May 2007
    126
    Code:
    (c:your_command_here)
    Senior Member
    Map 3D 2007
    Sep 2009
    142
    Thanks, now that I see it I remember there was something like this.
    Senior Member
    Map 3D 2007
    Sep 2009
    142
    I don't get it, how do I pass parameters to the command this way?
  5. #5
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    678
    upload the lisp
    Sorry for my English.
  6. #6
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    Depending on how it is written,
    Code:
    (your_command_here par1 par2 par3 ... parN)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  7. #7
    Senior Member
    Map 3D 2007
    Sep 2009
    142
    No, I'm using a command from another file. (c:command) works, but that way I can't supply parameters.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    So you are stuck with this construct?
    Code:
    (defun c:test (/ str)
      (setq str (getstring "\nEnter a String: "))
      (print str)
      (princ))
    (defun CallTest nil
      (c:test)
      (princ))
    This causes a problem as when the 'test' function is called (red), the blue code is evaluated, and the green code is not evaluated until the blue code is completed.
    Lee
  9. #9
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    You're not giving a lot of information. However, it sounds like the vlx prompts for selection and a few questions.
    What you could do is create your selection, then feed the selection and other required parameters to the routine through vla-sendcommand (I know I plug this command a lot).
    eg.
    ssget (no pickfirst)
    Code:
    (defun c:Test (/ ss)
      (if (setq ss (ssget "_:L"))
        (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "CommandName !ss Y N 0.5 ")))
    ssget (with pickfirst available)
    Code:
      (and (setq ss (ssget "_:L"))
           (sssetfirst nil ss)
           (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "CommandName Y N 0.5 ")))
    entsel
    Code:
    (defun c:Test (/ e)
      (if (setq e (car (entsel)))
          "CommandName !e Y N 0.5 ")))
    Oh yeah, and if in a situation where a space " " will not force the command to continue (ie: (getstring T "\nEnter String: ") ), you can replace the " " with "\n", which will act the same as if the user pressed the Enter key.
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    Nice idea Alan I hadn't thought of using that
  1. Best LISP Commands for Architecture
    By CADMASTER1128 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Aug 2009, 04:50 pm
  2. New to lisp commands
    By Dan5 in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th May 2008, 06:47 pm
  3. Loading LISP Commands
    By samanisc in forum AutoCAD General
    Last Post: 21st Aug 2007, 02:12 pm
  4. Undo multiple commands in lisp as one
    By gman in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2006, 05:57 pm
  5. Lisp for a sequence of commands...
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Feb 2006, 08:30 pm
