Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2007
    Sep 2009
    2
    Default Drawing to the correct dimensions
    Hi everyone,
    I need to draw a flange which has to be cut out at an engineering shop, its a basic shape and easy to draw. Now here is my problem:
    I need to draw in mm, as the measurments I have are in mm. I do know that autocad doesnt see mm/inches/cm etc...it just sees units, from my research, it states that I have to tell autocad that I want 1mm to equal 1 unit...but I cannot get it right..
    I was told to goto to the dimension tab=> dimension style => modify => primary units and then type 25.4 in the scale factor box...so I did it.....and re-drew my whole drawing...then after I printed it, the measurments on the paper was incorrect!
    Its frustrating, confusing and the more I research about it, the confusing its getting
    Can someone please help me by giving me a full explanation on how to take my measurments I have (which is in mm), draw it on autocad, and then print it onto a A4 piece of paper in 1:1 scale...
    Please, please I really need the help
    Full Member cedwards's Avatar
    cedwards's Computer Details
    Windows 7
    AutoCAD 2013
    Aug 2008
    Germantown, TN
    51
    Go to Format>>Units or just type units in the commandline
    Change the type to "Engineering"
    Change the insertion scale to "Millimeter"
    Then everything you draw will be in mm
    Forum Newbie
    AutoCAD 2007
    Sep 2009
    2
    Thanks for your response! But its still not working :-(
    Let me explain to you what I did from the very beginning:
    I open up AutoCAD2007; i then went to file=> new; I then opened "acad"; then went to Format=>units; changed it to "Engineering" and changed the insertion scale to millimeters; I then drew a line of 10 units; printed it; after measureing it with my ruler, the line is 24mm (not 10mm)
    So what am I doing wrong?
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    File New and select Metric template or Open new metric without template.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    did you plot to scale?
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  6. #6
    Forum Newbie Marc-S's Avatar
    Marc-S's Computer Details
    22" Viewsonic
    AutoCAD 2008
    Sep 2009
    Lafayette, LA
    9
    Quote Originally Posted by zipper View Post
    Did you dimension the line in CAD? What result did you get? Your problem might be in the way you printed...
  7. #7
    Windows 7
    AutoCAD 2013
    Aug 2008
    Germantown, TN
    51
    Well I'm amusing you are plotting to a 8.5x11.
    when you plot change the plot scale to 1:1
  8. #8
    Super Member nukecad's Avatar
    nukecad's Computer Details
    XP64
    Various machines.
    AutoCAD LT 2006
    Apr 2009
    NW Cumbria (English Lake District)
    500
    Are you plotting at 1:1 or Scale to Fit?
    By the way; if anyone is looking for metric drawing templates I posted a full set at this link-
    http://www.autocadeverything.com/hel...ight=templates
    *** Out of Beer Error ->-> Recovering Memory***
  1. displaying annotative dimensions in a viewport that not the correct scale?????????
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2010, 12:52 am
  2. drawing an object from different dimensions!
    By samerali2 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Nov 2008, 03:13 pm
  3. Drawing Dimensions
    By islandeast in forum AutoCAD Beginners' Area
    Last Post: 30th Oct 2008, 11:31 pm
  4. Find command does not zoom to correct drawing area
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 22nd Feb 2007, 11:00 pm
  5. Dimensions don`t seem correct.
    By Beebee in forum AutoCAD Beginners' Area
    Last Post: 9th Oct 2006, 11:22 pm
