Results 1 to 4 of 4
    Forum Newbie
    not specified
    Sep 2005
    Boston
    1
    Default Plotting 3d solids with shading on
    I'm using AutoCAD 2002, and I want to plot some 3D solids with shading on (to an eps, to bring into an Adobe Illustrator drawing). When I plot with the blocks rendered with flat shading, edges on, the plot preview is just the wireframe. Any suggestions?
    Senior Member craigp's Avatar
    AutoCAD 2007
    Jun 2005
    North Lincs, England
    346
    Default Re: Plotting 3d solids with shading on
    Quote Originally Posted by roszler
    I would shade the image as required then type in the SAVEIMG command. This will save the image as seen on the screen to a required filename (I think you can only save as BMP, TIFF and JPEG) Could you then re-save as an EPS?????
    Junior Member
    not specified
    Jul 2005
    Greece
    15
    What I'm doing is saveimg. What you have on screen is saved as a .bmp file. Then you print it.
    So quick bright things come to confusion...
    Senior Member
    AutoCAD 2009
    Sep 2005
    Fort Lauderdale, FL.
    265
    do a viewport in pspace, right click on viewport, go to properties and enable shading. should work.
