Here is a list of some free resources
http://cadpanacea.com/node/111
I do not know if this is the correct place to post this, but here it is. What are some of the best books to get for learning AutoLisp?
Thanks in advance.
Thanks for the help.
Sort of depends upon which version of Acad you are using. If you are using a Non-current version, do not buy the latest of anything, for may not have all commands you need to get job done available to you. I check out from local library a very old version as commands mentioned there tend to work on more modern systems still.
Don't get newer than the system you are aiming for.
Wm.
Technically true, but there has been very little added to Autolisp since visual lisp was incorporated over 10 years ago.
Tony Eeds aka Teeds aka Dad aka Grandpa
Proud member of the Peanut Gallery and the Pajama Economy
AutoCAD 2007 - 2008 arrived, and I just got an email that 2009 has shipped
Originally Posted by Teeds
