Support file search path - incorrect - lost shortcuts , hatching etc
Alicia Koch
I am using autocad 2006 and have inadvertently deleted the 1st path in the dropdown under support file path and as a result I cannot use any shortcuts, right clicks, hatching etc. I have tried to follow instructions for the default path for profile, templates and configuration files but still have no joy, any ideas please?
You could also create a new profile, set it to the default settings and use that as a reference for checking the paths in your profile.
Also, you can substitute %APPDATA% for the "C:\Documents and Settings\yourusernamehere\Application Data" part. That way it will work in any situation, without having to know the Windows profile name.
