Basic
versiona
Hi,
I would like to know some basic things about AutoCAD. I have to create some function in vba but I don't have a sufficient knowledge to begin.
My question is:
What is an entity?
What is a ModelPlace?
What is a Selection Set?
Do you have a "hierachic" between object:
ModelSpace is in an entity ?
What is in what
(((polilyne is in acadobject) is in Entity) is in ModelSpace) is in a Layer
Some help would be appreciated.
Thks
Versiona
An entity is an object.
Lines, circles and polylines are entities.
ModelSpace is the main block in a AcadDocument (drawing).
That block contains all objects you see in modelspace.
Other blocks are the PaperSpace block and alle the user defined blocks like for example a door and a title blocks. All blocks, or block definitions to be correct, are collections of entities. A block reference is also an an entity, in MS or PS.
You can for example do like this:
Set MS = Actovdocument.ModelsPace
For each Obj in MS
Do something
Look in Help and find the ObjectModel, like this:
