Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    AutoCAD 2010
    Sep 2009
    8
    Default Change Units inch to metric in the middle
    Hi guys,
    I'm picking up autocad using autocad 2010 version.
    Lets say a drawing's unit is mm, and now I change the unit to inch.
    I know if we just change the unit at beginning, all the lines of the drawing will be base on that unit.
    How bout if we change the unit to another along the way?
    will the drawing's measurements such as angle and annotation dimension be affected too?
    I know it's sound silly to ask this. But I was curious about it will it create huge changes or some changes we can't notice it easily?
    Thanks in advance!
    chewy
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    I would think that changing units midstream, an inherently bad idea, would cause changes that might not be easily noticed and could result in unintended errors re: accuracy.
    Just my personal opinion. I've actually never changed units (imperial to Metric or vice-versa) mid-course although I have done a drawing displaying alternate units (see Dimension Styles).
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    I tend to not use Imperial units at all, but I switch between using meters and millimeters once in a while. So, I'm adding a caveat to what I am about to say, since it might be different with imperial units.
    Agreed with Remark that it should really not be done, decided on a unit from the start and go with that. If you for some reason need a drawing (the actual drawing, for dimensioning it's different) in two systems, I would have two dwgs.
    That said, if you do change the units, as far as I know, nothing big will happen, as in the stuff that you have drawn will not change. What will change is the measurements of the lines, the dimensioning and ofc when you do a new line, you'll have to enter the lenght differently.
    Note though, that the lines will not scale to fit the new units. As for me, if I first draw in millimeters and then switch to meters, a line drawn as 15mm will now be 15meters.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    I do the layout of an Agricultural Show, and all the trade stands are in multiples of 10 feet. Apparently, the canvas tents only come in Imperial dimensions. One year, the organisers tried to metricate the stands making a 6m stand instead of 20 foot as previously, and every one noticed. They were complaining about the missing 4 inches.
    So now I draw up the stands in Imperial measurement, but take off the setting out coordinates in metric. To help me swiftly change from one system to the other, I have set up a scaling line, based on 0,0, so I can scale everything by reference. Works a treat.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Looks like accuracy is something to be concerned about when between Imperial and Metric. Very good example.
  6. #6
    Senior Member KiLLiNG-TiME's Avatar
    AutoCAD 2012
    Sep 2009
    London
    109
    Inches to Millimeters
    1 25.4
    2 50.8
    3 76.2
    4 101.6
    5 127.0
    6 152.4
    7 177.8
    8 203.2
    9 228.6
    10 254.0
    11 279.4
    12 304.8
    13 330.2
    14 355.6
    15 381.0
    16 406.4
    17 431.8
    18 457.2
    19 482.6
    20 508.0
    21 533.4
    22 558.8
    23 584.2
    24 609.6
    25 635.0
    26 660.4
    27 685.8
    28 711.2
    29 736.6
    30 762.0
    31 787.4
    32 812.8
    33 838.2
    34 863.6
    35 889.0
    36 914.4
    37 939.8
    38 965.2
    39 990.6
    40 1016.0
    41 1041.4
    42 1066.8
    43 1092.2
    44 1117.6
    45 1143.0
    46 1168.4
    47 1193.8
    48 1219.2
    49 1244.6
    50 1270.0
    All the above are correct you should never change units mid job etc, but if you have to, scale away chart above helps as does the cool image posted above by eldon (very smart).
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    How about fractions of inches to millimeters?
  8. #8
    AutoCAD 2012
    Sep 2009
    London
    109
    Maths not my strong point strangely enough ...
    There's a nice Units Converter on the Autodesk website under Services & Support/Units Converter (cannot post link as am new here)
    How about using quickcalc ?
    To convert fractions of an inch to mm
    Using AutoCAD’s QCALC, enter the as a sum dividing the bottom into the top.
    i.e. 3/32” = 3 divided by 32 = 0.09375”
    press enter
    This converts the fraction to a decimal.
    Now go down to Units conversion and complete the from and to values to inch and mm (as required)
    As you complete these to sum is calculated
    2.38125
    Hows that ?
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Well my point wasn't to have you produce another conversion chart. Sorry if I mislead you. But thank you just the same for the additional information.
  10. #10
    AutoCAD 2012
    Sep 2009
    London
    109
    Your welcome but I haven't my man, its just an example of how to use AutoCAD’s QCALC to do just what you wanted fractions of inches to millimeters.
  1. Change all dimensions from mm to inch in drawing
    By BullFrog12383 in forum AutoCAD General
    Last Post: 5th Nov 2009, 02:52 pm
  2. Possible to change colors in the middle of a printed string?
    By ajs in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Feb 2009, 12:37 am
  3. Units=inch Vs Meters
    By firsrate_caduser in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Mar 2008, 12:29 am
  4. How do I change metric to inch
    By frank_cali in forum AutoCAD General
    Last Post: 18th Apr 2007, 02:08 am
  5. metric units
    By Valerie in forum AutoCAD Beginners' Area
    Last Post: 6th Sep 2005, 09:07 pm
