+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Full Member
    Computer Details
    gotchy's Computer Details
    Operating System:
    XP Pro
    Motherboard:
    Intel DX68D8
    CPU:
    Intel i-5
    RAM:
    2 GB
    Graphics:
    Nvidia Quadro 5500 1GB
    Primary Storage:
    2 GB
    Monitor:
    HP 2009M
    Discipline
    Mechanical
    gotchy's Discipline Details
    Occupation
    Tool Designer
    Discipline
    Mechanical
    Details
    Tool and Die designing and making. Also 3-D Tool design.
    Using
    AutoCAD 2000
    Join Date
    Oct 2009
    Location
    R.I.USA
    Posts
    52
    Default Just learning to use the spline tool
    How are the points and handles deleted after a sketch is completed using the Spline Tool, in solidworks 2007? If I try to delete them, they distort the sketch, even though the sketch is dimensioned and thereby constrained.
    gotchy
  2. #2
    Forum Deity shift1313's Avatar
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    why are you trying to delete handles? are we talking about 2d splines or 3d splines?
    Typically when creating splines you use as few control points as possible. Draw a spline with two points only(start/end) and adjust the handles(this is 2d we are talking about). if you cant achieve the curve you want, add a point and so on. This removes excess control points which only complicates things. If you select the spline while in edit sketch mode there is a button to reset handles(current or all).
    how are you dimensioning the spline?
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
Similar Threads
  1. Still learning
    By flowerrobot in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2008, 11:22 pm
  2. learning vba
    By Gringo in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Sep 2008, 08:17 am
  3. Learning CAD options?
    By paul1966 in forum Catch All
    Last Post: 4th Aug 2008, 05:06 pm
  4. SPLINE tool?
    By nscherneck in forum AutoCAD Beginners' Area
    Last Post: 18th Sep 2007, 10:49 pm
  5. How custom tool button images are created for tool palettes
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2007, 04:13 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
