Results 1 to 5 of 5
    Junior Member
    not specified
    Aug 2005
    20
    Default how extract coodenates acadtext
    Hello people:
    I hava a problem with extract corrdenates the a acadobject.
    I have next example:
    dim objTexto as AcadText
    dim point( 0 to 2) as Double
    point=objTexto.TextAlignmentPoint
    But this is not right, anyone know make this??, thanx!!
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,639
    Default Re: how extract coodenates acadtext
    Quote Originally Posted by jandres
    Hello people:
    Do not use dim point( 0 to 2) as Double
    Use Dim point As Variant
    If you look at the documentation on TextAlignmentPoint, you will see that it returns a Variant.
    Junior Member
    not specified
    Aug 2005
    20
    Quote Originally Posted by rkmcswain
    Hello people:
    that not problem:
    dim Point as Variant
    Point = objTextoEmpalme.TextAlignmentPoint(1)
    This return 0....????
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,639
    that not problem:
    Did you read all the documentation on TextAlignmentPoint ?
    If the Alignment property is set to "acAlignmentLeft", then TextAlignmentPoint will return 0. Is this your case?
    There are also other items that affect the returned value of this property. Read the "Remarks" section.
  5. #5
    Junior Member
    not specified
    Aug 2005
    20
    that not problem:
    I not sure, but writte this after call alignamentpoint:
    objTexto.Alignment = acAlignmentRight
    MsgBox objTexto.TextAlignmentPoint(0)
    this return 0,thanx
