Results 1 to 5 of 5
    Senior Member
    Civil 3D 2012
    Apr 2009
    109
    Default VB.net: Perpendicular lines to a polyline
    I use vb.net. I work in 2D.
    I have a certain point (Point3D). I have a certain polyline. I need to draw a perpendicular line from the point to the polyline. Any ideas on how to do that??
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,968
    This is typically done with Curve.GetClosestPointTo(). The point returned from that method can be combined with the input point to create a line.
    Senior Member
    Civil 3D 2012
    Apr 2009
    109
    Thanx Seant,
    Can you please show me how to implement this statement? I have no idea how.
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,968
    There may be a detail or two overlooked in this sample, but it shows the general idea.
    Code:
       Public Sub Per2Poly()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            db.Pdmode = 66 'just to make the points more visible
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "Select a lwpline: ")
            peo.SetRejectMessage(vbCr & "Please select lightweight polyline only! ")
            peo.AddAllowedClass(GetType(Polyline), True)
            Try
                Dim per As PromptEntityResult = ed.GetEntity(peo)
                If per.Status <> PromptStatus.OK Then Exit Sub
                Dim mat As Matrix3d = ed.CurrentUserCoordinateSystem
                Dim pl As Polyline = tr.GetObject(per.ObjectId, OpenMode.ForRead)
                Dim ppo As PromptPointOptions = New PromptPointOptions(vbCr & "Select point from which to strike a perpendicular: " & vbLf)
                ppo.AllowNone = True
                Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                If ppr.Status <> PromptStatus.OK Then Exit Sub
                Dim basePt As Point3d = ppr.Value.TransformBy(mat)
                Dim pt As Point3d = pl.GetClosestPointTo(basePt, False) 'crux of the process
                Dim v3d As Vector3d = basePt.GetVectorTo(pt)       'Test if closest point is indeed perpendicular.
                Dim derV3d As Vector3d = pl.GetFirstDerivative(pt) '
                If v3d.IsPerpendicularTo(derV3d) Then              '
                    Dim ln As Line = New Line(basePt, pt)
                    Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                    ln.SetDatabaseDefaults()
                    btr.AppendEntity(ln)
                    tr.AddNewlyCreatedDBObject(ln, True)
                    tr.Commit()
                Else
                    ed.WriteMessage(vbCr & "Perpendicular not found!")
                End If
            Catch ex As Exception
                tr.Abort()
                ed.WriteMessage("Error during execution! " & ex.Message)
            Finally
                tr.Dispose()
            End Try
        End Sub
  5. #5
    Senior Member
    Civil 3D 2012
    Apr 2009
    109
    Thanx SEANT,
    I got it to work
  1. VB.NET: Lines crossing Polyline
    By Jozi68 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2009, 08:34 am
  2. Lisp routine for the widths of perpendicular lines
    By bsimpson in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2009, 02:56 pm
  3. Lisp routine for the perpendicular distance between two lines
    Last Post: 15th Nov 2008, 05:08 pm
  4. Drawing perpendicular lines
    By FCspecial in forum AutoCAD Beginners' Area
    Last Post: 20th Jun 2008, 06:12 am
  5. lines perpendicular to spline
    By Dario in forum AutoCAD General
    Last Post: 3rd Mar 2006, 09:36 am
