Action Recorder
happyunited
Action RECORDER autocad 2009.
This is a handy tolld for recording actions but does anyone know how I would actually find out the macro text that the action creates when it records so I could make a toolbar button?
I know I can just type the action I created but is there anyway of finding out the actualt macro like ^C^ etc etc
Not sure I understand your question.
Can you elaborate further what you are wanting to do ?
The macro to reset the scale list edit is ^c^c.-scalelistedit;_R;_Y;_E;
I can create a button because I already know this but say for example I created an action to do the same thing as above and it works perfect but just say I didnt know that the macro was ^c^c.-scalelistedit;_R;_Y;_E; for scalelisteditreset how would I extract that information from the action recorder so I could create a button?
I hope this is a bit clearer.
The simplest way would be to open the Ribbon, navigate to Tools, then Action Recorder.
Select the 'command' you wish to 'extract information from' from the drop-down list.
Select the black triangle just below the drop-down list, and it should be populated with all the commands recorded for that particular macro.
Thanks for that but I was thinking more of a file that simply gave me the marco output like ^c^c.-scalelistedit;_R;_Y;_E; where I dont have to manually do that all myself.
You're aware that you can "play" a macro created with the Action Recorder from the command line right? Why? Because it now acts like a command. Can't you just put the "command" on a button? Why does it have to be the entire macro?
