Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2008
    Oct 2009
    1
    Default Convert/Import Jpeg image to DWG file.
    Does anyone have any idea how I can covert or import a jpeg image to DWG file using autocad 2008?
    Is there any other way to do this.
    LOST
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    Your question is confusing.
    Are you trying to convert a jpg into a dwg or are you trying to import a jpg into a dwg? There is a big difference.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2011
    Dec 2008
    Rancho Cordova, CA
    539
    If you mean taking an image (i.e. raster file) and turning it into a vector file (i.e. lines, arcs, etc) then you would need AutoDesk's Raster Design software. It does a great job but as with any software there is a small learning curve. It is quite easy to learn though.
    Calvin
    Soli Deo Gloria
    Super Member
    AutoCAD pre 2000
    Nov 2008
    578
    The quality of a JPEG image is suspect, but can tell you how I cheated.
    I opened up a whole new blank drawing. I imported the JPEG image into there.
    The opened up the parent drawing and XREF'd the image drawing on in. Then moved it into position etc.
    Got out of parent drawing and at original location for JPEG I then resized it and rotated it.
    Then after the need and deed was done, it got bleeped out via the XREF command. When on applicable layer and began adding text then.
    One way to cheat here is to introduce Adobe Photoshop, and rotate or alter the JPEG image therein. Just place new image into most recent image drawing file, as old name and keep going.
    Wm.
  1. How to convert a JPEG image into PDF?
    By Hilda Thompson in forum Catch All
    Last Post: 9th May 2013, 01:41 pm
  2. How to convert dwg file into any image file.
    By naveenit307 in forum AutoCAD General
    Last Post: 1st Oct 2008, 06:13 pm
  3. Fatal error when attaching a JPG/JPEG image file
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 16th Oct 2006, 11:13 pm
  4. Pls Help. Convert .DWG to any image file
    By marks in forum AutoCAD General
    Last Post: 29th Apr 2006, 10:52 am
  5. Is it possible to convert an auto-cad file into a .jpeg?
    By Quackmac in forum AutoCAD General
    Last Post: 20th Jun 2005, 02:25 pm
