Results 1 to 9 of 9
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,302
    Default Hatch Around Text Added Later
    Is there a simple method for adding text to a hatched area and then have the hatch pattern clear from around the text similar to what happens when you hatch with existing text already in place?
    It's deja vu, all over again.
    Senior Member
    Glen Smith's Computer Details
    Win XP
    Dell Studio XPS 1645
    Intel i7 Q720 @ 1.6Ghz
    8 Gig
    Electrical 2010
    May 2008
    Cary, NC
    418
    Are you familiar with the Express tools text mask command? Will that do what you want?
    Glen
    “Progress isn't made by early risers. It's made by lazy men trying to find easier ways to do something." Lazarus Long in Time Enough For Love
    Junior Member
    AutoCAD 2010
    Aug 2009
    Sioux Falls,SD
    22
    Annotate tab then select wipeout, draw whatever shape you need to create for your text and all is well! Oh, if you do the wipeout after text, the text will disappear.
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Quote Originally Posted by whitehaint View Post
    Will the South Dakota Chips still be there?
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  5. #5
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by Bill Tillman View Post
    If you dbl-click on hatch or type HE to hatchedit, you can add boundaries (will allow you to select additional objects).
    Forget wipeouts, MText has a background setting.
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  6. #6
    Full Member
    AutoCAD 2008
    Jun 2009
    97
    I use the trim command to modify the hatch.
  7. #7
    Senior Member
    AutoCAD 2010
    Mar 2009
    130
    activate the text box so that the blue grips are showing. Dont open it for text editing. Open the properties window, under the text heading, change Background to yes.
  8. #8
    Full Member
    AutoCAD 2008
    Jun 2009
    97
    Quote Originally Posted by Ollie8974 View Post
    Thanks, learned something new today.
  9. #9
    Junior Member
    AutoCAD 2010
    Aug 2009
    Sioux Falls,SD
    22
    Quote Originally Posted by Tankman View Post
    Uhhh.....huh?
  1. Toolbars cannot be added or removed
    By jlbuller in forum AutoCAD General
    Last Post: 27th Aug 2009, 11:57 am
  2. Ramp - Angle Added for some reason
    By mattbarb in forum AutoCAD Beginners' Area
    Last Post: 23rd Apr 2008, 04:09 pm
  3. Text added in paperspace hides behind viewport
    By malcolm_macaulay in forum AutoCAD Beginners' Area
    Last Post: 7th Mar 2007, 03:12 pm
