+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Forum Deity shift1313's Avatar
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default Autodesk Algor Simulation
    Anyone using it? Its now offered to the student community.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  2. #2
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    I started playing with it and it seems to be a really powerful tool. A little hard to work around since its not at all like the other Autodesk interfaces but I havent gone through any tutorials yet. If you are a student and want to get into any sort of CAE check this out.
    www.mysolidbox.com
  3. #3
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    I see this thread has a lot of views but no replys
    I've only used this a few times. I was able to do some basic fea on a few single parts. I tried to do some flow analysis on my motorcycle bodywork but I made the mistake of trying to insert the entire bike assembly which put a severe draw on the system. After 2 hrs it still wasnt loaded
    I would still like to find someone else who uses this.
    www.mysolidbox.com
  4. #4
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,905
    Default
    I downloaded and installed on my machine but it crashes right after spash screen.
    I am using the earlier version in the classroom - it does take a lot of tutorials to get used to compared to the built in tools in Inventor and SolidWorks. We are doing as much as we can in all three porgrams (and Pro/E Mechanica) - pick up a little trick in each program that can then be used in all of them once we figure it out.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    Do you focus on FEA JD or do you guys dive into all aspecs of CAE?
    www.mysolidbox.com
  6. #6
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,905
    Default
    Quote Originally Posted by shift1313 View Post
    Do to a faculty member leaving I'm just getting into FEA. My background is in manual and CNC machining (now in a virtual environment rather than out on the shop floor). My particular interest now is in Rapid Prototyping technologies.
    I suspect these new analysis tools will make complex analysis far more approachable (with inherent mis-use dangers) to a far wider audience. I think overall it will be a big plus - a game changer despite users who will incorreclty use the technology.
  7. #7
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    Quote Originally Posted by JD Mather View Post
    In the past i have always designed things to be machined/cut and done the NC programming but recently I have been designing injection molded parts which has opened up mold analysis tools and mold flow which have been very helpful. At work I only have access to Simple FEA and Flow analysis with Solidworks which is why I have been learning Algor on the side.
    www.mysolidbox.com
  8. #8
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,905
    Default
    ...I have been designing injection molded parts which has opened up mold analysis tools and mold flow which have been very helpful.
    You can download Inventor Tooling (search Google) for download site and install with your student version Inventor Professional.
    Since Autodesk purchased Moldflow they have been integrating moldflow technology into Inventor.
    In addition to the built in tutorials there are some good on-line classes (free) videos at http://au.autodesk.com see MA 222-1 and MA 218-3
    Why you are there you should check out MA 308-1 on Inventor Fusion.
    Some Algor stuff in MA 9310 and MA 304
    And checkout the Manufacturing Keynote.
    You might send an email to MFG-BETA@autodesk.com and put AU in the subject line if you are interested in seeing beta of possible future technology.
  9. #9
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    Well since our university dropped autodesk in 07 I dont have current versions at work. I do however have ugs NX6 which has some excelent mold tools built in. Mold flow is one thing our license doesnt cover unfortunately. I will however check that stuff out on my home machine when i get the chance.
    Thanks JD
    www.mysolidbox.com
  10. #10
    Forum Newbie
    Using
    Inventor 2011
    Join Date
    Oct 2010
    Posts
    1
    Default More on Algor please
    Hi
    I am trying to find some really good exercises for flow analysis in Algor.
    Also any recommended background reading to understand CFD better.
    Thanks
    Jason
Similar Threads
  1. Please help with Inventor simulation
    By maceng in forum Autodesk Inventor
    Last Post: 29th Apr 2010, 10:18 pm
  2. balance beam simulation
    By karimmec in forum SolidWorks
    Last Post: 24th Aug 2009, 12:49 pm
  3. Simulation
    By joes in forum SolidWorks
    Last Post: 1st Jun 2009, 01:48 pm
  4. Simulation report
    Last Post: 12th May 2009, 03:29 pm
  5. simulation suite
    By jamfu in forum Autodesk Inventor
    Last Post: 7th Sep 2008, 06:21 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
