gilsoto13 Posted October 14, 2009 Share Posted October 14, 2009 Hi Everyone: I think I can surprise many people with this final task I am willing to develop somehow... I want to Make a lisp to allow me to select an entire detail or plan view... then this lisp must split the selection for 3 different object type groups: Dimensions & leaders, text (and if possible mtext), and blocks... And then the lisp will aply 1 command or lisp to each one of those 3 selection groups... This is to standarize a Detail or plan according to our standard text, dimension and block sizes... I will try to take care of this part... But I dont know how to split the selection into 3 selection sets... Any help will be appreciated.. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 14, 2009 Share Posted October 14, 2009 Hi Everyone: I think I can surprise many people with this final task I am willing to develop somehow... I want to Make a lisp to allow me to select an entire detail or plan view... then this lisp must split the selection for 3 different object type groups: Dimensions & leaders, text (and if possible mtext), and blocks... And then the lisp will aply 1 command or lisp to each one of those 3 selection groups... This is to standarize a Detail or plan according to our standard text, dimension and block sizes... I will try to take care of this part... But I dont know how to split the selection into 3 selection sets... Any help will be appreciated.. Once you've made the selection, just iterate through them applying procedure A, B or C based on object type. (assoc 0 or (vla-get-objectname using cond. Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 20, 2009 Author Share Posted October 20, 2009 Once you've made the selection, just iterate through them applying procedure A, B or C based on object type. (assoc 0 or (vla-get-objectname using cond. Ok, I found this made by you... I am gonna start from here.. ;text & leader delete ;only selects text, mtext & leaders to erase ;created: alan thompson - 4.17.08 (defun c:TX (/ ss) (prompt "\nSelect text & leaders to erase: ") (setq ss (ssget '((0 . "TEXT,MTEXT,LEADER")))) (if ss (progn (command "erase" ss "" ) (princ (strcat "\n " (rtos (sslength ss)) " Text and/or Leader objects have been deleted.")) );progn (princ "\nNo text selected, try again.") );if (princ) ) Then, How can I add 3 different selection groups with a specified assigned abbreviation, and run a specified command or function to each selection group at once?... I tried to just write something but I guess I gotta keep reading.. ;Detail updater to current scale ;tried to be written: Paulo Gil .. today (defun c:UD (/ ss ss2 ss3) (prompt "\nSelect a whole detail to update: ") (setq ss (ssget '((0 . "TEXT,MTEXT")))) (setq ss2 (ssget '((0 . "INSERT")))) (setq ss3 (ssget '((0 . "DIMENSION,LEADER")))) (if ss (progn (command "_.chprop" ss "color" "blue" "") );progn (princ "\nNothing selected, try again.") );if (if ss2 (progn (command "_.chprop" ss2 "layer" "Patt" "") );progn (princ "\nNothing selected, try again.") );if (if ss3 (progn (command "_.chprop" ss3 "layer" "Dims" "") );progn (princ "\nNothing selected, try again.") );if (princ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 20, 2009 Share Posted October 20, 2009 Just make one large selection set, then iterate through the list using cond and if it "MTEXT" matches (cdr (assoc 0 (entget e)))), then change the color. BTW, I obviously don't mind you using my code, but please remove my name from anything that I did not write. ;Detail updater to current scale [color=Red];created: alan thompson - 4.17.08[/color] (defun c:UD (/ ss ss2 ss3) Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 20, 2009 Share Posted October 20, 2009 Give this a try, untested and in vla, because I'm lazy... (defun c:UD (/ #SS) (vl-load-com) (cond ((setq #SS (ssget ":L" '((0 . "MTEXT,TEXT,INSERT,DIMENSION,LEADER")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (cond ;; text, mtext ((vl-position (vla-get-objectname x) (list "AcDbMText" "AcDbText")) (vla-put-color x 5)) ;; blocks ((eq (vla-get-objectname x) "AcDbBlockReference") (vl-catch-all-apply 'vla-put-layer (list x "Patt")) ) ;; dimension, leader ((wcmatch (vla-get-objectname x) "*Leader*,*Dimension*") (vl-catch-all-apply 'vla-put-layer (list x "Dims")) ) ) ;_ cond ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
JohnM Posted October 20, 2009 Share Posted October 20, 2009 Do you think it would be easer to window the objects the list the windows corner points The jus pass it to the 3 ssget functions? Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 20, 2009 Share Posted October 20, 2009 Do you think it would be easer to window the objects the list the windows corner pointsThe jus pass it to the 3 ssget functions? Why go though all that trouble, when you can just iterate through it and change objects based on object type. Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 20, 2009 Author Share Posted October 20, 2009 I haven´t checked it out either... but I guess this is what I wanted, the correct order for three different selection sets and only one lisp... Now I guess I can use the (vl-cmdf "_.any command") on these "lists" I actually want to use this new lisp for 2 different purposes... one is for a "Detail scale updater"... and the other will be the "mask all" So, in the "Detail Scale updater" when you select a bunch of objects the lisp will apply 1 lisp function to filtered blocks... 1 lisp function to Text, Mtext 1 command (Dim--Update) to Dimensions and leaders The "mask all" will apply 1 Command to Dtext (textmask) 1 lisp function to Mtext (yours, jejeje) 1 lisp or vlx to Dimensions This is what I am trying to do... but there's no hurry for this... i'll try to go step by step. I am still working hard everyday to finish the blocks collection.. I finished extracting all collections... The next step is just merging all the blocks into their respective dwgs for compilation. I am using a Batch dxf to dwg successfully, and I will try a batch PDF to DWG today afternoon for some construction details that were available only in pdf format. (vl-catch-all-apply 'vla-put-layer (list x "Patt")) Give this a try, untested and in vla, because I'm lazy... (defun c:UD (/ #SS) (vl-load-com) (cond ((setq #SS (ssget ":L" '((0 . "MTEXT,TEXT,INSERT,DIMENSION,LEADER")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (cond ;; text, mtext ((vl-position (vla-get-objectname x) (list "AcDbMText" "AcDbText")) (vla-put-color x 5)) ;; blocks ((eq (vla-get-objectname x) "AcDbBlockReference") (vl-catch-all-apply 'vla-put-layer (list x "Patt")) ) ;; dimension, leader ((wcmatch (vla-get-objectname x) "*Leader*,*Dimension*") (vl-catch-all-apply 'vla-put-layer (list x "Dims")) ) ) ;_ cond ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
mark_acadd Posted October 21, 2009 Share Posted October 21, 2009 nice one!.but how can i apply those lisp in my autocad!..i dont know how to put it.i mean the codes..where can i put it!..help me guys..im just a newbies in field of autocad and i hope i can learn a lot from!..thanks and god bless! Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 21, 2009 Share Posted October 21, 2009 nice one!.but how can i apply those lisp in my autocad!..i dont know how to put it.i mean the codes..where can i put it!..help me guys..im just a newbies in field of autocad and i hope i can learn a lot from!..thanks and god bless! Well, without any additional information, just change object types, layer names, colors, etc. to what you want. Give some parameters and we can make something work. Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 21, 2009 Author Share Posted October 21, 2009 Well, without any additional information, just change object types, layer names, colors, etc. to what you want. Give some parameters and we can make something work. Well, at this time it's all pretty good...But If you want some extra-work, I was wondering if I could find a small lisp routine or some code to automatically change selected text and mtext to current style and height without prompt... that' the only thing left to complete the first lisp... (defun c:UD (/ #SS) (vl-load-com) (cond ((setq #SS (ssget ":L" '((0 . "MTEXT,TEXT,INSERT,DIMENSION,LEADER")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (cond ;; text, mtext ((vl-position (vla-get-objectname x) (list "AcDbMText" "AcDbText")) (vla-put-color x 5) [color=red] (vla-put-height x (getvar 'textsize))[/color] [color=red] (vla-put-stylename x (getvar 'textstyle))[/color] ) ;; blocks ((eq (vla-get-objectname x) "AcDbBlockReference") (vl-catch-all-apply 'vla-put-layer (list x "Patt")) ) ------------------------------------ ;Here is the place to apply a function (another lisp) that Lee Mac wrote for me.. the "Bu.lsp" But it shouldn't be ;applied to all selected blocks, only those we use as standard, so, these blocks must be re-filtered to grab only ;those in a list, and then apply the bu.lsp to that last selection of blocks. ;Bu.lsp Update selected blocks to current Dimscale, supports Normal, attributed and dynamic blocks ;by Lee Mac from Cadtutor, Sep. 2009 (defun c:bu (/ *error* doc oldc ss sel scl) (vl-load-com) (defun *error* (msg) (if doc (vla-EndUndoMark doc)) (if oldc (setvar "CMDECHO" oldc)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " msg " **"))) (princ)) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (setq oldc (getvar "CMDECHO") scl (getvar "DIMSCALE")) (setvar "CMDECHO" 0) (prompt "\nSelect Blocks to match current dimscale... ") (if (setq ss (ssget '((0 . "INSERT")))) (progn (vla-StartUndoMark doc) (command "_.-objectscale" ss "" "_add" "1:1" "") (setvar "CANNOSCALE" "1:1") (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet doc)) (foreach x (if (eq :vlax-true (vla-get-IsDynamicBlock Obj)) '(XEffectiveScaleFactor YEffectiveScaleFactor ZEffectiveScaleFactor) '(XScaleFactor YScaleFactor ZScaleFactor)) (vlax-put-property Obj x scl)) (if (eq :vlax-true (vla-get-HasAttributes Obj)) (command "_.attsync" "_Name" (vlax-get-property Obj (if (eq :vlax-true (vla-get-isDynamicBlock Obj)) 'EffectiveName 'Name))))) (vla-delete sel) (vla-EndUndoMark doc))) (setvar "CMDECHO" oldc) (princ)) ;; dimension, leader ((wcmatch (vla-get-objectname x) "*Leader*,*Dimension*") (vl-catch-all-apply 'vla-put-layer (list x "Dims")) ) ) ;_ cond ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond ) ;_ defun ------------------------------- ;; dimension, leader ((wcmatch (vla-get-objectname x) "*Leader*,*Dimension*") (vl-catch-all-apply 'vla-put-layer (list x "Dims")) ---------------------------------------------------- ;Here is the place to apply the command Dimupdate to filtered dimensions and leaders ----------------------- ----------------------- Bu.lsp textup.lsp Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Share Posted October 22, 2009 Well, at this time it's all pretty good...But If you want some extra-work, I was wondering if I could find a small lisp routine or some code to automatically change selected text and mtext to current style and height without prompt... that' the only thing left to complete the first lisp... Here, I was bored.... (defun c:TextUp (/ #SS) (cond ((setq #SS (ssget "_:L" '((0 . "MTEXT,TEXT")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (vla-put-height x (getvar 'textsize)) (vla-put-stylename x (getvar 'textstyle)) ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
mark_acadd Posted October 22, 2009 Share Posted October 22, 2009 where i can put all of the codes u gave!..how can i apply it to cad?.. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Share Posted October 22, 2009 where i can put all of the codes u gave!..how can i apply it to cad?.. http://www.cadtutor.net/forum/showthread.php?t=1390 Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 22, 2009 Author Share Posted October 22, 2009 Here, I was bored.... (defun c:TextUp (/ #SS) (cond ((setq #SS (ssget "_:L" '((0 . "MTEXT,TEXT")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (vla-put-height x (getvar 'textsize)) (vla-put-stylename x (getvar 'textstyle)) ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Incredibol... It works... I guess I just left to do the standard blocks list... which is a very long list... maybe near a thousand block names... But if you have a chance... I uploaded the lisp files to apply to filtered blocks, text and mtext, It will be for us like using Revit but in Autocad, this way we can change everything involved in a detail scale automatically in one step. A big big accomplishment. But is it possible to apply those 2 lisp to filtered selections as you did here? http://www.cadtutor.net/forum/showthread.php?t=37475&page=2 Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Share Posted October 22, 2009 Incredibol... It works... I guess I just left to do the standard blocks list... which is a very long list... maybe near a thousand block names... But if you have a chance... I uploaded the lisp files to apply to filtered blocks, text and mtext, It will be for us like using Revit but in Autocad, this way we can change everything involved in a detail scale automatically in one step. A big big accomplishment. But is it possible to apply those 2 lisp to filtered selections as you did here? http://www.cadtutor.net/forum/showthread.php?t=37475&page=2 You could , but it would be better suited to just combine the two or turn them into subs. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Share Posted October 22, 2009 Is this what you are wanting? (defun c:UD2 (/ #SS) (vl-load-com) (cond ((setq #SS (ssget ":L" '((0 . "MTEXT,TEXT,INSERT,DIMENSION,LEADER")))) (vlax-for x (setq #SS (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) ) ;_ setq (cond ;; text, mtext ((vl-position (vla-get-objectname x) (list "AcDbMText" "AcDbText")) (vla-put-color x 5) [color=Red] (vla-put-height x (getvar 'textsize)) (vla-put-stylename x (getvar 'textstyle))[/color] ) ;; blocks ((eq (vla-get-objectname x) "AcDbBlockReference") (vl-catch-all-apply 'vla-put-layer (list x "Patt")) ) ;; dimension, leader ((wcmatch (vla-get-objectname x) "*Leader*,*Dimension*") (vl-catch-all-apply 'vla-put-layer (list x "Dims")) ) ) ;_ cond ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 22, 2009 Author Share Posted October 22, 2009 That's exactly what I wanted... but without (vla-put-color x 5) This was just to start... How would you Update dims and leaders to current settings as using dimupdate command, but with vla? How would you make this lisp a subfunction?... I guess first you change the (defun c:bu (/ *error* doc oldc ss sel scl) for something like this: (defun AT:bu (/ *error* doc oldc ss sel scl) and then when you get your blocks, you go like: (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (AT:Bu (vla-get-insertionpoint x) (if (vlax-property-available-p x 'EffectiveName) (vla-get-effectivename x) (vla-get-name x) ) ;_ if And then, I don't know... I actually don´t know anything... I just find the things... You could , but it would be better suited to just combine the two or turn them into subs. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Share Posted October 22, 2009 That's exactly what I wanted... but without (vla-put-color x 5) This was just to start... How would you Update dims and leaders to current settings as using dimupdate command, but with vla? How would you make this lisp a subfunction?... I guess first you change the (defun c:bu (/ *error* doc oldc ss sel scl) for something like this: (defun AT:bu (/ *error* doc oldc ss sel scl) and then when you get your blocks, you go like: (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (AT:Bu (vla-get-insertionpoint x) (if (vlax-property-available-p x 'EffectiveName) (vla-get-effectivename x) (vla-get-name x) ) ;_ if And then, I don't know... I actually don´t know anything... I just find the things... Not sure about dimup, never had a reason to try it, if i have some time, I'll look. As far as converting a routine to a sub, from the simplest change, just remove the c: You don't have to add AT:, that's just what I add to my (Alan Thompson) subroutines. What you have posted will not work...what's c:BU? Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted October 22, 2009 Author Share Posted October 22, 2009 Not sure about dimup, never had a reason to try it, if i have some time, I'll look. As far as converting a routine to a sub, from the simplest change, just remove the c: You don't have to add AT:, that's just what I add to my (Alan Thompson) subroutines. What you have posted will not work...what's c:BU? So, I guess I kind of understand how to make a subroutine... but still can´t do it by myself... I am not in a hurry with this.... so I will wait for heaven to light you on again, hopefully you'll find some more time later and we can keep this post going on... Steps left to finish: - Changing Bu.lsp to subrutine to apply to filtered blocks.. - Finding the way to apply current dim settings to filtered dims and leaders from selection... -Get all in shape to work together without prompt. Quote Link to comment Share on other sites More sharing options...
