+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Full Member
    Using
    not specified
    Join Date
    Jul 2005
    Posts
    27
    Default Tips on shrubbery? Landscaping?
    Hello all...
    So I render homes/commercial buildings by modelling in CAD then importing into Max...to get my finished product, i throw it into Photoshop to add landscaping. I always look online to compare my work to others, and i see that a lot of people do landscaping in 3d max. I am not a pro at Max by any stretch, but i would like to add shrubs and landscaping in Max instead of Photoshop....can someone steer me in the right direction?
    Here is some stuff that i've done, so you can see what i do...
  2. #2
    Full Member
    Using
    not specified
    Join Date
    Jul 2005
    Posts
    27
    Default
    The first image shows a building i did in Max, and pretty much everything above the road was photoshopped (trees, rock wall, sky, and yes, powerlines)...
    The second image shows a house, also done in Max, and aligned over an existing house, cleaned up in photoshop...they didnt want any landscaping...
    The third image is a house i did a few years ago, before i got into Max...i modelled it in CAD, then dropped it into photoshop, and did the entire thing in photoshop. Not fun. But you can see the landscaping, which is the point of this thread...i'd rather do that in Max than in photoshop...
  3. #3
    Super Moderator Cad64's Avatar
    Computer Details
    Cad64's Computer Details
    Operating System:
    Windows 7 Profesional x64
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    Intel Core I7 3770K 4.1 Ghz Quad Core 3rd Gen
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Nvidia GeForce GTX 570 1280MB GDDR5
    Primary Storage:
    SATAII 500GB 7200 RPM
    Secondary Storage:
    Western Digital My Book Studio Edition II - 2TB capacity
    Monitor:
    HPf2105 21" LCD Widescreen & Cintiq 21ux
    Discipline
    Multi-disciplinary
    Cad64's Discipline Details
    Occupation
    Freelance Digital Artist
    Discipline
    Multi-disciplinary
    Details
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,420
    Default
    You may want to have a look at this thread: http://www.cadtutor.net/forum/showth...ighlight=xfrog
    Lately I've started adding the majority of my plants in Photoshop, rather than using 3D plants. However, I will use full 3D plants and trees in the foreground, up close to the camera, but anything in the mid-ground or background will usually be done in Photoshop. It's just faster and easier to add them in Photoshop than spend a lot of time placing them in the scene and then dealing with system slowdown due to massive amounts of poly's. And then the long render times, ugh! Plus, it's difficult to always find the right 3D tree or shrub, and my boss is a real stickler about using the exact plants that are on the plans. But in Photoshop, I can always find photos of plants to use, so it's no big deal. But anyway, it all depends on time constraints and the level of realism required. If I have the time, I will use 3D plants, but time is usually not on my side.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  4. #4
    Full Member
    Using
    not specified
    Join Date
    Jul 2005
    Posts
    27
    Default
    So, Cad64, people in this profession, such as yourself, use photoshop to add plants? How funny, I thought i was the only one. I thought it was pretty hack, but if others do it, maybe i'll stick to the photoshop method. Altho, I'll check out your link...thanks!
  5. #5
    Computer Details
    Operating System:
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Primary Storage:
    Secondary Storage:
    Monitor:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,420
    Default
    Well, in a production environment, where everyone wants everything yesterday and you're competing with overseas firms that charge less than half for the same product, you have to cut corners wherever possible. I've just found that adding things like plants/trees in Photoshop is much faster and easier than placing 3D plants/trees manually in Max. And render times are much, much faster without them. I do add them in strategic places though, where it makes sense, but I try to keep them to a minimum and then fill in the rest in Photoshop. The only time you really need full 3D plant material is when you are doing animation. If you're just doing still renders, Photoshop plants work just fine.
    But . . . Having said all that . . . When I'm working on my own personal projects, where time is not an issue, I do place the 3D plants manually in Max and render out the full scene. Then I take the rendered image into Photoshop and touch up any areas that need attention.
    It just depends on the situation.
  6. #6
    Super Member Tankman's Avatar
    Computer Details
    Tankman's Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,794
    Default
    Nice "stuff" ironman! Adding shrubs? I wouldn't have a clue.
    I'm sure you'll hear from many forum rendering guru's. Thanks for displaying your fine "stuff."
    Where is the ironman posting from? Landscape looks a bit familiar.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  7. #7
    Super Member
    Using
    AutoCAD 2008
    Join Date
    Jul 2007
    Posts
    536
    Default
    For grass - I'd say it's quite good to take a sample of some grass already in the scene and then blend that with another grass texture or merge it using an opacity map though some scenes are easier than others. Some grass textures are too uniform to look realistic.
    Also I think blurring your CG elements to match that off the photo references, or photo background in your scene helps. Also adding noise too.
    Attached are some pics of a test I did a while ago - not really used this yet at work though.
    Using AutoCAD2012, Civil 3D 2012, 3DS Max 2012, AutoCAD MEP 2011, Imagemodeler 2009, Zbrush, Solidworks, PTGui, Photomatix, Photoshop
    PORTFOLIO: http://www.flickr.com/photos/47676682@N04/
  8. #8
    Junior Member
    Computer Details
    cec_casbie_novice's Computer Details
    Operating System:
    Windows Vista
    Computer:
    PC, with logitec trackball mouse and two screens
    Using
    Map 3D 2010
    Join Date
    Jul 2010
    Location
    UK
    Posts
    10
    Default
    nice use of photoshop and cad pkg
Similar Threads
  1. Only tips, please
    By BlackAlnet in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2009, 10:12 pm
  2. Your Top Tips
    By wannabe in forum AutoCAD General
    Last Post: 28th Oct 2008, 06:34 pm
  3. Landscaping and site planning
    By AFCC Inc. in forum AutoCAD General
    Last Post: 15th May 2008, 09:58 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
