+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
  1. #1
    Forum Newbie
    Using
    AutoCAD 2007
    Join Date
    Feb 2008
    Posts
    6
    Default How to make a solid out of this
    Hello:
    Can someone explain me how to make a solid out of this.
    I have tried intersectin solids and surfaces, no luck.
    Finally if made it with lines, making regions, extruding etc. But now i want to make it a solid.
    This is the farthest i've been able to get:
    Then i tried to "lean faces" but autocad doesn't let me.
    thanks for your time, sorry for my english
    regards,
    pacho
  2. #2
    Super Member Raggi_Thor's Avatar
    Using
    AutoCAD 2008
    Join Date
    Aug 2007
    Location
    Trondheim, NORWAY
    Posts
    718
    Default
    Have you tried LOFT between the curves?
    You could try Rhino, the trial lets you save 25(?) times.
    There you have the command EdgeSrf where you select four edge curves to define a surface. Finally all the surfaces can be made into one solid.
    Can you post a dwg?
    Last edited by Raggi_Thor; 19th Oct 2009 at 07:35 am. Reason: EdgSrf, not EdgeSurf
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
  3. #3
    Forum Newbie
    Using
    AutoCAD 2007
    Join Date
    Feb 2008
    Posts
    6
    Default
    Hi:
    Thanks for the replay
    Here is the attach file:
    ok.dwg
    regards,
    pacho
  4. #4
    Using
    AutoCAD 2008
    Join Date
    Aug 2007
    Location
    Trondheim, NORWAY
    Posts
    718
    Default
    As I mentioned, you can make 3D surfaces in AutoCAD with the LOFT command. See Image. It's a real hassle compared to Rhino because curves are "consumed" (deleted when they are used) and you cant select the edge of a surface as a curve in your next loft.
    Now, How do we make this watertight surface model into a solid in AutoCAD?
  5. #5
    Super Member SEANT's Avatar
    Using
    AutoCAD 2012
    Join Date
    Aug 2005
    Location
    Rhode Island
    Posts
    1,968
    Default
    One of the options for the Slice command uses a Surface as a cutting object. So;
    if the bottom Region were extruded as shown in the second image of the original post – except extruded past the uppermost point
    the compound, upper surface lofted as described in post #4
    then those two elements work nicely with the Slice command to produce the attached solid. Surface also left in drawing.
  6. #6
    Forum Newbie
    Computer Details
    Nostromo's Computer Details
    Operating System:
    Vista
    Computer:
    Compaq CQ70
    Motherboard:
    CPU:
    Pentium Dual T3200
    RAM:
    2Gb
    Graphics:
    Primary Storage:
    Toshiba mk1652gsx ata, 120Gb
    Monitor:
    Generic PnP, 17"
    Using
    AutoCAD 2009
    Join Date
    Jan 2009
    Location
    Preston, Lancashire
    Posts
    7
    Default
    Hi
    Seant is correct, see attached with cylinder subtracted to proove solid oksolid.dwg
    Hope I have attached ok, never done it before.
    Pacho, Is there a practical use for the item being modeled
  7. #7
    Forum Deity shift1313's Avatar
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    Quote Originally Posted by Raggi_Thor View Post
    before the loft type DELOBJ and set the variable to 0. your curves will no longer be deleted after the loft. Once you have a closed surface you can convert from Surface to solid. CONVTOSOLID
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  8. #8
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    I would have drawn the base, extruded it, then created two extruded surfaces for the slice just as mentioned by seant.
    www.mysolidbox.com
  9. #9
    Using
    AutoCAD 2008
    Join Date
    Aug 2007
    Location
    Trondheim, NORWAY
    Posts
    718
    Default
    Quote Originally Posted by shift1313 View Post
    Thanks, I had a feeling there was a setting for this
    I tried to convert those multiple surfaces to a solid but AutoCAD didn't want that..
  10. #10
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    I think the kicker of that command is you need to have a thickness to the surface. honestly i dont use it because its much easier to slice a solid with a surface than to try and "fill" the surface. You can type THICKEN, select a surface and give it a thickness as long as this doesnt introduce some self intersecting geometry. Especially with this shape, extrude then two slice operations would be the way to go.
    edit. it would take more than a simple extruded surface to trim the top but its still a loft operation/surface slice.
    www.mysolidbox.com
Similar Threads
  1. I need HELP please!! How to make this SOLID.
    By Mad_TaZ in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Dec 2008, 05:57 am
  2. Can't make things solid
    By Rog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Oct 2008, 10:10 pm
  3. make model into solid
    By deangelis in forum SolidWorks
    Last Post: 7th Dec 2007, 03:46 pm
  4. How do I make this into a solid?
    By p2bc in forum AutoCAD General
    Last Post: 30th Aug 2005, 03:39 am
  5. How to add texture or make solid?
    By Vaker in forum AutoCAD General
    Last Post: 13th Dec 2004, 02:36 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
