Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    Default How to make lines bold?
    Anyway to select the lines I need to be a certain lineweight?
    Senior Member Cadologist's Avatar
    Cadologist's Computer Details
    Windows 7 Professional
    Hewlett-Packard Z420 Workstation
    POS Fisherprice Beta Nukemaster v2.6
    Intel Xeon CPU E5-1620 v2 @ 3.70Ghz
    16 GB
    Nvidia Quadro K2000
    Three Hamsters, Alumimum Wheel
    Busted up 1970's 'Vintage Green' File Cabinet
    Dual Monitors (24" LG LCD)
    Multi-disciplinary
    Cadologist's Discipline Details
    Corporate CAD Development
    Multi-disciplinary
    AutoCAD 2015
    Oct 2009
    Canada
    136
    Yes, there are several ways to do this.......
    1. Use 'plines' and assign a width to them, or use pedit to make the 'line' a pline prior to doing the width. This isn't specifically lineweight but will produce the same idea.
    2. Draw the line, select it and use the 'lineweight toolbar' to assign a line weight.
    3. Move the linework onto a layer and assign that layer a certain color that corresponds to a pen color setting in your color table (ctb file) to print thicker then others. ie: set magenta to print with a 0.7 size rather then the default 0.25 pen width). Again, this isn't specifically line weight but will produce the same idea.
    4. Move the linework onto a layer and assign a line weight to that layer itself, making sure the lineweight of that entity is set to 'bylayer'.
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    how do you move the linework to a layer?
    16 GB
    Nvidia Quadro K2000
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Oct 2009
    Canada
    136
    You cross window and select the linework and use either the layers pulldown toolbar and select the layer you want it to go to, or use the properties pane. There are other ways but those are the most common.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    One way is to click on the line and if you have Quick Properties enabled change the layer there. Another option is to click on the line and change the layer in the full-blown Properties window. Do you know how to access either one or both of these features?
  6. #6
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    so click on the lines, the blue handles show up, when i'm done selecting i hit the quick properties and select the layer i want?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Yes, that's one way to do it. BTW...those "handles" are called grips.
    How many lines do you want to change to a different layer?
  8. #8
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    5 lines all connected together
  9. #9
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    ok, got them on the right layer, but the lines on all layers are still the same thickness, nothing is bold even though I have their lineweight assigned to what I want per layer
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Look at the bottom of your screen. See those ten buttons off to the left? Turn "on" the button for Show/Hide Lineweight. It's the second button in from the right.
  1. text prints out bold when its NOT bold
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 24th Feb 2012, 01:41 pm
  2. how to make all lines ONE ... !!
    By CAD-LOVER0208 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Nov 2008, 05:39 pm
  3. how do i make a surface from lines?
    By guiheer in forum AutoCAD General
    Last Post: 5th Oct 2007, 01:42 pm
  4. Make all lines coplanar
    By ktaylor in forum AutoCAD General
    Last Post: 20th Jul 2005, 11:42 pm
  5. how to make isometric lines...
    By me_go_fast in forum AutoCAD General
    Last Post: 11th Jul 2005, 05:50 pm
