Hi All..I have been practicing using a older book(copyright 1990) and it has some decent exercises in it. I was able to do this one but it seems I can"t find the proper way to do this..First drawing a line a certain distance..ortho on,click the first point anywhere,move curser to the left and click again. that gives me a line at 180 degrees at what ever length..Line command again starting at the second point of the first line..after clicking that point,I type in @2.38<150 that gives me a line2.38 long at 150 degrees..now how do i make a third line relative to the second line so that the angle is 75 degrees and a certain length..the picture shows what I am trying to draw..using the polar cordinates you get an angle based off the UCS( which is set at world) when you try to draw the third line ..that makes the angle between line 2 an 3 not the angle that I want..To make the drawing,I rotated the ucs -30 degrees..But there has to be a better way than that..Mike
Using ACAD 2000
Thanks Kencaz..in that thread there is a post asking how to find that angle..in my drawing the third line angle is 45..adjusting the angle of the UCS -30 degrees make the line 75 degrees to the second line..doing the math as you explained..but in this exercise in this old book there is a series of lines drawn on the page all relative to the line previous..if each angle has to be made doing the math..lots of room for a error..I just thought ACAD had a 'relative to last line' type of command ..Mike
Using ACAD 2000
Here is the total exercise..I was able to do it,I just did alot of double checking to be sure it was right..Mike
Using ACAD 2000
Have a look at Polar Tracking. In the settings you can set the Increment angle to 15°, and the Polar Angle measurement to Relative to last segment.
For Relative to last segment to work, you have to be drawing the lines in the same command, otherwise you have to snap to Endpoint of the last line drawn.
Welcome to the forums New2CADmike!
If that happens, keep in mind 0° is at 3 o'clock.
Angles move counterclockwise, 90° is then at 12 o'clock.
180° would be at 9 o'clock, 270° of course at 6 o'clock.
Feels like you're workin' backwards but, it works! Have fun!
AutoCAD 2000 I found to be an excellent program.
That's the way it is folks!![]()
Tankman
"When the well is dry, we know the worth of water." Ben Franklin ~ 1746
Thanks for the welcome Tankman,but I have been here for a while it is just I haven't been here for a while and things get rusty without use..the fastest way that I figured to do this is draw the second line on top of the first line to the correct length and then using the rotate command,spin it to the correct angle..using the counterclockwise direction you mentioned..Mike
Using ACAD 2000
To use Polar tracking, you need a delicate mouse hand and good eyesight.
But it is posible to draw your exercise in one go (given a few more dimensions)![]()
