NCsaba Posted October 28, 2009 Share Posted October 28, 2009 Hello! AutoCAD LT 2002 not working properly. Opens the DWG file, but in case of any change in the file shows the following error: Unhandled Access Violation Reading 0x401983c Exception at 6544bab7h If I give Administrator or Power User rights to user it works fine, but it has to remain a simple user. Any suggestion would be appreciated Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 28, 2009 Share Posted October 28, 2009 Try using the Recover command instead of Open. Does AutoCAD still crash? What OS is being used? Is this a networked computer? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 28, 2009 Share Posted October 28, 2009 A couple of other questions come to mind. When did the problem first occur? What is the source of the drawings? Does this happen with just a select few drawings or any drawing that you open? Quote Link to comment Share on other sites More sharing options...
