Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    AutoCAD 2002
    Jun 2009
    16
    Question UCS 2D plan to 3D elevation
    Hi I hope the title explains what I'm trying to do.
    I have a plan of a multi sided object and 3D points.
    I've created lots of UCS's for each face.
    What I'd like to do is set a particular UCS so that it is square in the view in plan view, which I manage, then I want to view it as a flat on elevation effectively with z values going up x values to the right and y values the other direction! Traditionally I would have "flipped" the data to be viewed in this way like an elevation of a building would appear.
    I'm really struggling and not quite sure why I can't work this out as surely this is the point of ucs's, the presets of top bottom etc, or the 3d orbit aren't good enough I need to be able to be square on to the information, or at least I think I do!!
    Thanks in advance ( I hope!)
    Rossi.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    You can be "square on" to any "face" simply by changing the origin and orientation of your UCS even in ACAD 2002.
    Junior Member
    AutoCAD 2002
    Jun 2009
    16
    Hmm I'm looking daft now, cheers.
    Do I just swap Z for y ? is it easy all I can see is a way to rotate an axis!
    I'm using 2009
    Junior Member
    AutoCAD 2002
    Jun 2009
    16
    just had a minor brain wave.
    You mentioned "face" my drawing does not have a defined single face I can pick, however maybe I could get round this by creating a face which is the same orientation as my ucs?
    If so any tips welcome (on what exactly a face is)
    Thanks
    Rossi
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Well you mentioned objects and 3D points so I wasn't exactly sure what you wanted to square up to.
    Old school here so forgive me. But when I type UCS at the command line and press Enter I can them type "O" (for Origin) and relocate it then I can repeat the UCS command and this time type "3" for 3 point and follow the prompts for base point and positive direction of both X and Y.
  6. #6
    Junior Member
    AutoCAD 2002
    Jun 2009
    16
    thanks once again sounds do-able at home at the moment will give it a crack in the morning!
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Please let us know how you make out. If you have further questions pertaining to this particular thread continue to post them here. Questions on new topics deserve a new thread. Good luck.
  8. #8
    Junior Member
    AutoCAD 2002
    Jun 2009
    16
    Yeah baby!!! I done it!
    Not quite how you said, I was getting quite confused with defining the 3 points. Oh and it's not becasue you said you're old school I spent most of my time on rel 12! Only just getting to grips with 2009!!
    So I typed into command line "view"
    Up popped a window
    I expanded preset views
    selected Front
    changed the set relative to box to my current UCS
    then I can set the view to be front and it is square to my ucs with z values up and x to the right!
    Thanks for pushing me along here.
    Cheers
    Rossi
  9. #9
    Forum Newbie
    Land Dsektop 2009
    Oct 2009
    2
    You can rotate its axis easily...
  10. #10
    Forum Newbie
    Land Dsektop 2009
    Oct 2009
    2
    Good you have done it!! keep it up!!
  1. plan elevation and sections
    By prabhathjp in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Apr 2009, 12:22 pm
  2. Plan + Elevation + Section
    By sarahsoames in forum AutoCAD Beginners' Area
    Last Post: 2nd Jan 2008, 09:03 pm
  3. Transfer Ortho Elevation data to Plan views
    By Morphim in forum AutoCAD Beginners' Area
    Last Post: 8th Nov 2007, 01:30 pm
  4. From floor plan to elevation
    By nathan008 in forum AutoCAD General
    Last Post: 24th Oct 2007, 11:27 am
  5. 3D to 2d elevation?
    By nivradolobo in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2007, 05:25 pm
