FrankPB Posted October 29, 2009 Share Posted October 29, 2009 Hi Grateful for advice received from forum last week which enabled me to get my autocad R2008 up and running again without the need for a re-install. Program works well now except on start up or each time I load a drawing I get message customisation file load failed. file not found. and the file is named. When I type in menuload at command line, browse to file and load it everything is ok. The file can be seen in the Tools/Options/Main Customisation Files search path. Could anyone please advice me how to make this cui file load automatically? Quote Link to comment Share on other sites More sharing options...
sparklerach Posted October 30, 2009 Share Posted October 30, 2009 Go to Tools and Load application. After you have found the file and loaded it, you then have to add it to the start up suite (in the same dialogue box). Click 'Contents', browse for the file and click add. Hope this helps Quote Link to comment Share on other sites More sharing options...
