Thick lines in plot preview
stahlhelm79
Hi folks!
I am changing some bits on A1 ACAD 2002 drawings. I've finished with the changes and I want to plot. But in plot preview some lines, hatches and linear dimensions what I've added much more thicker then the other lines and looks awful. In model or layout everything looks fine.
Tried all printers in preview, result is the same.
Any body cames accross with this problem maybe?
Thank you
Regards
Did you try a test plot of a small area of the drawing that exhibits this behavior?
I didn't try do that but I printer the whole layout and it is exaclty shown on the preview some areas affected.
Any hints?
Thank you
Were any lineweights assigned in Layer Properties Manager?
Did you check you ctb or stb file?
You are a star, they were on 1 mm lineweight.
Thank you very much!!!!!
