+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Hanna
    Default Create Searchable PDF Text
    There are several questions contained in this post:
    I am using AutoCAD 2000 to create postscripts. To create the postscripts I plot-to-file using the PostScript Level 1 plot driver that I created with the AutoCAD Add-A-Plotter Wizard. I then use Adobe Distiller 4.0 to convert the postscripts into PDF format. When I open these PDFs in Adobe Acrobat 4.0 I cannot edit them, or search for text.
    Question 1: Does anyone know how I can create my postscripts so that the text is searchable in the PDF?
    P.S. (no pun intended): I am using the Windows 2000 OS.
    If you want to go deeper into the issue, read on:
    I believe I have it narrowed down to a font problem. Currently we use the AutoCAD txt.shx font. If I change the fonts to the TrueText courier.ttf font and plot-to-file using a plot driver called Adobe PDFWriter (which automatically converts the post-scripts to PDF), then I can search the PDF for text, as long as the text is in the courier font. However, if I use the PostScript Level 1 driver or Adobe Distiller to convert the postscripts to PDF, then I cannot search for any text, even the text that uses the True Type courier font. Also, the really important part of the documents (the engineering diagrams), look horrible when converted with PDFWriter.
    Question 2: Does anyone know why the postscript/PDF created with the PDFWriter driver is searchable, but the postscript/PDF created with the AutoCAD driver is not?
    Question 3: Is there a way to make the plot driver or Distiller recognize txt.shx as a font, so I don’t have to convert my many drawings into courier?
    Any help on this matter would be greatly appreciated! Thank you!
    - Hanna
  2. #2
    Administrator CADTutor's Avatar
    Computer Details
    CADTutor's Computer Details
    Operating System:
    Windows 7 Home Premium 64bit
    Motherboard:
    Asus P7P55D-E PRO
    CPU:
    Intel Core i7-860
    RAM:
    4GB PC3-12800 C8 Corsair Dominator
    Graphics:
    NVIDIA Quadro FX 1800 768 MB
    Primary Storage:
    Intel X25-M SSD 160GB
    Secondary Storage:
    Samsung Spinpoint 320GB
    Monitor:
    BenQ FP241W 24" Wide
    Discipline
    Education
    CADTutor's Discipline Details
    Occupation
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Discipline
    Education
    Using
    AutoCAD 2015
    Join Date
    Aug 2002
    Location
    Hampshire, UK
    Posts
    3,742
    Default Re: Create Searchable PDF Text
    My guess would be that the AutoCAD .SHX fonts are treated as geometry when they are plotted to PostScript whereas the .TTF fonts retain their ascii character codes. If this is true, you will need to change all your SHX text to TTF. The easiest way to do this is to redefine the text style using a different font. Ideally, find a TTF font that looks the same as the TXT.SHX AutoCAD font. I don't know of one but I can't believe that one doesn't exist.
    Maybe someone else out there can give a more definitive answer.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  3. #3
    Hanna
    I had a feeling that I would be converting all the fonts. *Sigh.* Thank you for your quick response, I appreciate the help!
    "CADTutor - the best free tutorials on the web... definitely!"
  4. #4
    Forum Newbie
    Discipline
    Structural
    Using
    not applicable
    Join Date
    Sep 2017
    Location
    Manhattan, NY
    Posts
    2
    Default
    Is this solved yet?
  5. #5
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,878
    Default
    Quote Originally Posted by Pink Zeppelin View Post
    Is this solved yet?
    Depends. What version of AutoCAD are you using?
  6. #6
    Forum Newbie
    Discipline
    Structural
    Using
    not applicable
    Join Date
    Sep 2017
    Location
    Manhattan, NY
    Posts
    2
    Default
    I'm using CADMATIC Hull (marine structure design software). I hope you guys know about this software.
  7. #7
    Luminous Being RobDraw's Avatar
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,179
    Default
    Is that a .dwg format?
    Drafting is a breeze.
  8. #8
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    6,056
    Default
    Quote Originally Posted by RobDraw View Post
    Looks to be Autocad compatible.
    Volume and repetition do not validate opinions forged in the absence of thought.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
