I was using the above code to read attributes of blocks in dwg files. Now I need to do a similar thing. I need to read text object values with a specific layer in a dwg file.Code:Public Function Oku() 'Dim objacad As AcadApplication Dim thisdrawing As AcadDocument Dim objBlok As AcadBlockReference Dim element As Object Dim ArrayAttributes As Variant Set objacad = CreateObject("AutoCAD.Application") objacad.Documents.Open (DwgName) Set thisdrawing = objacad.ActiveDocument 'objacad.Visible = True For Each element In thisdrawing.ModelSpace If element.EntityType = 7 Then If element.HasAttributes = True Then Set objBlok = element ArrayAttributes = element.GetAttributes If objBlok.Name = blok_adi Then adet = UBound(ArrayAttributes) - LBound(ArrayAttributes) For j = LBound(ArrayAttributes) To UBound(ArrayAttributes) Matrix(k, j, 1) = ArrayAttributes(j).TagString Matrix(k, j, 2) = ArrayAttributes(j).TextString Next Else For i = LBound(ArrayAttributes) To UBound(ArrayAttributes) If ArrayAttributes(i).TagString = tag_adi Then adet = UBound(ArrayAttributes) - LBound(ArrayAttributes) For j = LBound(ArrayAttributes) To UBound(ArrayAttributes) Matrix(k, j, 1) = ArrayAttributes(j).TagString Matrix(k, j, 2) = ArrayAttributes(j).TextString Next 'MsgBox "Attribute Değeri : " & ArrayAttributes(I).TextString GoTo sonraki End If Next End If End If End If sonraki: Next objacad.Quit End Function
The above code works fine. What it does is:
1. Opens the target dwg file
2. Checks for entitytype is a block or not
3. Checks for entity has attributes or not
4. If the element has attributes, it reads the attribute values
Now I need to revise my code but I don't know how ! Any help would be appriciated.
Things I wonder:
1. how can I check if an element is a text or not
2. how can I specify a layer and look for the object in that layer
I guess i may figure out the rest if I sum1 would show me the way
Thanks & best wishes from Turkey
1.- Use a SelectionSet object, filtering by text.
2.- Use other SelectionSet, filtering by specified layer.
SelectionSet example:
Code:'Seccion: crea un SelectionSet Dim selectionSet1 As AcadSelectionSet 'selectionSet1.Delete Set selectionSet1 = acadapp.ActiveDocument.SelectionSets.Add("BloquesSS") 'Fin de seccion 'Seccion: agrega objectos al selectionSet1 Dim FilterType(0) As Integer Dim FilterData(0) As Variant FilterType(0) = 1 FilterData(0) = "Text" 'fin de seccion
