Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member KevUK's Avatar
    AutoCAD 2014
    Nov 2009
    UK
    65
    Default Degrees Minutes Seconds
    My knowledge in Autocad is minimal, as I am a site setting out engineer.
    My question is: How can I draw a line by using DMS (Whole Circle Bearings) NOT surveyors.
    eg: 100.000 metres @ a bearing of 30 degrees 45 minutes 45 seconds!!
    If I enter it as @100.000<30.7625. There is no problem
    If I enter it as @100.000<30d45'45'' It freezes!!!
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    What is Angle > Type set to in Units? Probably Decimal, right? Change it.
    AutoCAD 2014
    Nov 2009
    UK
    65
    Units are set to DMS, Not decimal!!
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    No need to shout.
    I'm using 2010 it doesn't matter what I set Angle Type to. I can input the angle as a decimal or DMS and it excepts both (without freezing). Not sure why your input freezes things up. When did the problem first occur?
    Have you used any custom LISP routines lately?
  5. #5
    AutoCAD 2014
    Nov 2009
    UK
    65
    No need to shout.
    Sorry, did not mean to shout
    Could it be the way I am imputting the angle!
    Example:
    @100.000<30d45'45''
    Exactly as I type it in
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    I just duplicated what you wrote and had no problem. What is shown below was taken directly from my text screen (F2):
    Command: _line Specify first point:
    Specify next point or [Undo]: @100.000<30d45'45"
    Angle Type was set to Decimal and Precision was set to "0" places yet AutoCAD took the input just as I typed it. Doing a "List" on the line showed the distance as specified but the angle, for obvious reasons, was shown to be 31 as I expect it would. The point of the exercise was to get AutoCAD to freeze on the unexpected input. It did not. Good news for me but it does not explain why you are having a problem.
    Have you had any problem in the past typing in DMS?
    What is the source of the drawing? Did it come from an outside contractor?
    What software was used to create the drawing?
  7. #7
    AutoCAD 2014
    Nov 2009
    UK
    65
    Start AutoCAD-New Drawing
    Draw a line
    AutoCAD text window:
    Regenerating model.
    AutoCAD menu utilities loaded.
    Command:
    Command:
    Command: _line Specify first point: 100.000,100.000
    Specify next point or [Undo]: @100.000<30d45'45''
    Point or option keyword required.
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by KevUK View Post
    Draw a line... ...
    Seems to be some information missing in that sequence. What template did you start with or where did you set Units in that sequence?
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    It does not matter what your angle units are set to, AutoCAD will always understand an angle input of 30d45'45".
    But, because your command line says "Point or option keyword required." it does not understand what you are typing. If it did understand, the command line would say "Specify next point or [Undo]".
    Something is amiss and perhaps other minds may find the solution. It is bound to be simple.
  10. #10
    AutoCAD 2014
    Nov 2009
    UK
    65
    Quote Originally Posted by JD Mather View Post
    Create New Drawing
    Use Wizard
    Advanced Setup
    Decimal (Precision: 0.0000)
    Angle-Deg/Min/Sec (Precision: 0d00'00.00'')
    Direction for angle: North
    Orientation for angle: Clockwise
    Area: 420X297
  1. Converting Degrees, Minutes, Seconds to NE
    By jonosbg in forum AutoCAD General
    Last Post: 21st Jun 2010, 05:40 pm
  2. degrees and minute to degrees minutes and seconds
    By shekluv in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2008, 09:32 pm
  3. QuickCalc support for degrees, minutes, and seconds
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 4th Feb 2007, 03:01 pm
  4. QuickCalc support for degrees, minutes, and seconds
    Last Post: 3rd Feb 2007, 02:40 am
  5. Entering angles using Degrees & Minutes
    By gcp310 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Sep 2004, 03:01 pm
