Results 1 to 8 of 8
Thread: block library
    Senior Member alijahed's Avatar
    alijahed's Computer Details
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    Cape Town/South Africa
    386
    Default block library
    Hi All,
    I have so many blocks in different drawings which they are really handy to use. for having a library of those(put all of them in the same place) is there any way to call them or address them?
    I don't want to use "wblock" which is going to be
    and also don't want to use "Design center" or "Tool palette".
    Cheers
    Ali
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,097
    WBlock...out.
    Design Center...out.
    Tool Palette...out.
    I don't know, what's left? Magic?
    Buy a digitizer and do a little customization such that you can pick the blocks straight off the digitizer with the puck.
    There used to be a program called Block Librarian but it's been a while. Don't know if it is still available.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,097
    Re: Block Librarian. Out of circulation but there is a new product called CADView.
    http://www.softsource.com/bl.html
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    WBlock...out.
    Tool Palette...out.
    like your reply,
    I have reasons...
    let me put it in this way,
    Can we extract all of our blocks from a drawing as separate dwg files, then I can put them in that library folder?
    Cheers
  5. #5
    Senior Member ica_cici's Avatar
    AutoCAD 2008
    Mar 2009
    123
    I usually put my blocks in one folder, so I can insert them in another drawing quickly " just give the right name and no more confuse "
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    You can do it with just plain jane Autocad and a new menu.
    The acad menu has a secton called image heres the steps
    1 wBlock out all your blocks into individual drawings
    2 open the drawing get it looking pretty on the screen and then "MSLIDE" this creates a snap shot of the cad drawing
    3 you edit the menu file to add your slides and you can add ^c^cInsert block1 repeat block two an image appears on the screen .
    This just loads from the normal menu we have 7 image (block) libraries displayed some have over 20 blocks just pick by name or by image.
  7. #7
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Sorry having trouble uploading the example image will send you a private email of the menu and image let me know
    Here is a prioir answer http://www.cadtutor.net/forum/showthread.php?t=40598
    IT have probably done something again they never tell us we find out when it does not work anymore.
  8. #8
    Junior Member RFCAD2319's Avatar
    AutoCAD 2009
    Nov 2009
    20
    Quote Originally Posted by alijahed View Post
    like your reply,
    I have reasons...
    Cheers
    1. you can insert each block then wblock it to a pathed folder for easy insertion. Or wblock them to block specific folders such as pipes, joints etc.
    2. you can insert every block you want to use into a single drawing so it is nested, then set that drawing as your default template. When you want to insert a block it should be listed in your blocks list in the INSERT dialogue box.
    Problem with that is if you have a large number of blocks your list will be very long.
    I would recommend you wblock every thing into separate pathed folders, it will be much easier to manage your blocks.
    or CADfx has a nice block manager for around $95. cadfx.com
  1. locating the block library
    By alijahed in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Nov 2009, 03:17 am
  2. Block Library
    By BWells in forum Feedback
    Last Post: 5th Nov 2008, 10:53 am
  3. Block Library
    By Red Freak in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2007, 11:25 pm
  4. Menu Block Slide Library
    By Absntmind in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jul 2006, 03:00 pm
  5. trouble importing my symbol/ block library
    By Sir Bergersworth in forum AutoCAD Beginners' Area
    Last Post: 12th Aug 2005, 09:40 pm
