How would that point or vertex be selected?
Hello
I'm looking for a rhino script similar of command
_AnnotateCrvEndPoints
but only for annotate one single position (points or vertex ) in my rhinomodel.
Thanks
- whith the mouse
in the same way like inserting a point whith
command _Point (snap on)
P.s. I'd like to have the possibility to
select the TEXT HEIGHT.
This routine is based on what I could find out about _AnnotateCrvEndPoints. It used Annotation Dots which, unfortunately, don't have any resizing capabilities.
Code:Option Explicit Sub Dot2Point ' Declare variables Dim strLocation Dim strDot Dim arrPoint With Rhino Do arrPoint = .GetPoint("Select point at which to set dot: ") If IsArray (arrPoint) Then strLocation = .Pt2Str(arrPoint, 2) strDot = .AddTextDot (strLocation, arrPoint) Else Exit Sub End If Loop End With End Sub Dot2Point
Thanks Seant
That's just what I was looking for
Hello
it is possible to modify this script
just for annotate the lenght of the curve
(annotation in the mid point of the curve)
Thanks
