Results 1 to 6 of 6
Thread: OLE attachments
    Forum Newbie
    AutoCAD 2011
    Nov 2009
    9
    Default OLE attachments
    I have many drawings that have OLE attachments that are Excel spread sheets. In some drawings the attachment won't open?
    How can I find the source file location or get around this.
    Senior Member todouble22's Avatar
    AutoCAD 2009
    Nov 2009
    Maine, U.S.A
    243
    Quote Originally Posted by Bob Foley View Post
    bob,
    type xref at the command line and the dialog box will open up and the details of the ole objects will be on the bottom as to where they are located.
    - todd -
    Forum Newbie
    AutoCAD 2011
    Nov 2009
    9
    That just shows the Xref's
    I'm having trouble opening an embedded OLE object (Excel file)
    AutoCAD 2009
    Nov 2009
    Maine, U.S.A
    243
    are the paths the same as to where it is located and where it is referencing the excel file from? you may need to repath it or are they not opening at all? are you even getting a window as to where the file would be?
    - todd -
  5. #5
    Forum Newbie
    AutoCAD 2011
    Nov 2009
    9
    The only thing i get when I click on the attachment is the proporty box.
    It does not show any kind of path.
  6. #6
    AutoCAD 2009
    Nov 2009
    Maine, U.S.A
    243
    The only thing i can think of is when you click on the ole (excel file) it should open in excel and from there you can get the properties of the file. Maybe you'll want to attach them as a file so you can reference it? I hope it helps?
    - todd -
  1. xref attachments into drawing problem...
    By fresh in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2009, 02:10 pm
  2. xrefs as attachments?
    By td88 in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2009, 03:55 am
  3. manage attachments d bar does not function
    By reggy in forum Feedback
    Last Post: 23rd Jul 2008, 08:53 pm
  4. Deleting attachments of x'ref'd dwgs
    By Arnis in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2008, 05:42 pm
  5. Attachments/Drawings
    By sentinel in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jan 2006, 11:35 am
