Results 1 to 2 of 2
    Full Member
    AutoCAD 2010
    Nov 2009
    48
    Default geodetic and geographical coordinates
    Dear members and other viewers
    Hello
    I research About this problem that :
    Is it Possible that an user in autocad's enviroment
    use of geodetic and geographical coordinates insread of UTM coordinates ?
    In other words :
    use of curvilinear coordinates insread of linear coordinates ? ( latitude and longitude Instead of E , N )
    or Should be done at first step coordinates transformations ?
    Senior Member wizman's Avatar
    AutoCAD 2009
    Nov 2007
    Abu Dhabi / Philippines
    408
    For me, it is always an extra step to convert first to UTM not like when you're in Map, civil3d, gis, where you'll just pick the zones.
  1. Coordinates
    By Coosbaylumber in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Sep 2009, 04:26 pm
  2. Need to go from x,y,z to x,y coordinates
    By cabltv1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Feb 2009, 02:59 pm
  3. Coordinates
    By matt41129 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2007, 01:01 am
  4. Can I insert all the geodetic map file ...
    By vector in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2007, 10:09 pm
  5. X,Y, and Z coordinates
    By Scot C. Perry in forum AutoCAD Beginners' Area
    Last Post: 14th Jul 2005, 03:51 pm
