Results 1 to 9 of 9
    Senior Member
    Architectural DT 2005
    Sep 2006
    334
    Smile low points and high points on a 3d poly
    Sorry about the miss-spelt title! should be "Low points and high points on a 3d poly"!
    Does anyone have a routine to put low points and high points on a 3d poly?
    I have a 3d poly which goes up and down (various sags and crests) over half a mile. I need a routine that puts a cross and the text "HP" for a high point on the crest and "LP" for the low point on a sag in varying locations along this polyline.
    I know this one is going to be a challenge as the 3d polylines are not curves but straights.
    Anyone heard of a routine like this or have one?
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Thread title adjusted.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,587
    Quote Originally Posted by iain9876 View Post
    The sample picture would be easier for understanding
    ~'J'~
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    Here would be a basic starting point:
    Code:
    (defun c:extz3dp (/ ss i en ed vn vd pl maxz minz)
    ;;;ARG -> point  text_value text_size
      (defun make_tick (p v s)
        (entmake (list (cons 0 "LINE")
                 (cons 10 (polar p (* pi 0.25) s))
                 (cons 11 (polar p (* pi 1.25) s))))
                 (cons 10 (polar p (* pi 0.75) s))
                 (cons 11 (polar p (* pi 1.75) s))))
        (entmake (list (cons 0 "TEXT")(cons 1 v)(cons 6 "BYLAYER")
                       (cons 7 "STANDARD")(cons 8 "0")
                       (cons 10 p)(cons 11 p)(cons 39 0.0)
                       (cons 40 s)(cons 41 1.0)(cons 62 256)(cons 72 4))))
      (and (setq ss (ssget "X" (list (cons 0 "POLYLINE")
                                     (cons 66 1)
                                     (if (getvar "CTAB")
                                         (cons 410 (getvar "CTAB"))
                                         (cons 67 (- 1 (getvar "TILEMODE"))))
                                     (cons -4 "&")
                                       (cons 70 8)
           (setq i (sslength ss))
           (while (not (minusp (setq i (1- i))))
                  (setq en (ssname ss i)
                        ed (entget en)
                        vn (entnext en)
                        vd (entget vn))
                  (while (and (= "VERTEX" (cdr (assoc 0 vd)))
                              (= 32 (cdr (assoc 70 vd))))
                         (setq pl (cons (cdr (assoc 10 vd)) pl)
                               vn (entnext vn)
                               vd (entget vn))))
           (foreach v pl
             (if (not maxz)
                 (setq maxz v))
             (if (not minz)
                 (setq minz v))
             (if (>= (caddr v) (caddr maxz))
                 (setq maxz v))
             (if (<= (caddr v) (caddr minz))
                 (setq minz v)))
            (make_tick minz "LP" 2)
            (make_tick maxz "HP" 2))
       (prin1))
    Some limits or thing to address:
    What happens if there are 2 or more points that have the min or max z values
    Filter only 3DPOLYINEs
    Uses VERTEX control points only
    A (ssget) filter to skip curved fitted 3DPOLYs would be nice
    Adjust the call to make_tick for size
    Adjust make_tick TEXT values to your needs
    -David
    R12 (Dos) - A2K
  5. #5
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,587
    Quote Originally Posted by David Bethel View Post
    -David
    Hi David
    Nice code as always!
    I have found one more limit:
    if the start point or end point have Z=0
    program failed
    ~'J'~
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    1,926
    Quote Originally Posted by fixo View Post
    program failed
    That doesn't surprise me <g>
    Maybe this will help:
    Code:
    ; (*-debug-* 9 "extz3pd")
                       (cons 10 p)(cons 11 p)(cons 39 1e-8)
                       (cons 40 s)(cons 62 256)(cons 72 4))))
      (if (setq ss (ssget "X" (list (cons 0 "POLYLINE")
                                    (if (getvar "CTAB")
                                    (cons -4 "<NOT")
                                      (cons -4 "&")
                                      (cons 70 4)
                                    (cons -4 "NOT>")
                                    (cons -4 "&")
                                      (cons 70 8))))
                          ed (entget en)
                          vn (entnext en)
                          vd (entget vn)
                          pl nil)
                    (while (= "VERTEX" (cdr (assoc 0 vd)))
                                 vn (entnext vn)
                                 vd (entget vn)))
                    (setq maxz (list (car pl))
                          minz (list (car pl)))
                    (foreach v pl
                      (cond ((equal v (car maxz) 1e-8))
                            ((> (caddr v) (caddr (car maxz)))
                             (setq maxz (list v)))
                            ((equal (caddr v) (caddr (car maxz)) 1e-8)
                             (setq maxz (cons v maxz)))
                            ((equal v (car minz) 1e-8))
                            ((< (caddr v) (caddr (car minz)))
                             (setq minz (list v)))
                            ((equal (caddr v) (caddr (car minz)) 1e-8)
                             (setq minz (cons v minz)))))
                    (foreach p minz
                        (make_tick p "LP" 2))
                    (foreach p maxz
                        (make_tick p "HP" 2)))))
      (prin1))
    -David
    R12 (Dos) - A2K
  7. #7
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,718
    This should mark all the Peaks and Troughs on your polyline:
    Code:
    ;; High-Low Point  ~  Lee McDonnell (Lee Mac)  ~  01.12.2009
    (defun c:Hi_Low (/ mk_pt ent i pt dif t1 t2)
      (vl-load-com)
      (defun mk_pt (p txt)
        (entmake (list (cons 0 "LINE") (cons 10 (polar p (/ pi 4.) 2.))
                       (cons 11 (polar p (/ (* 5 pi) 4.) 2.))))
        (entmake (list (cons 0 "LINE") (cons 10 (polar p (/ (* 3 pi) 4.) 2.))
                       (cons 11 (polar p (/ (* 7 pi) 4.) 2.))))
        (entmake (list (cons 0 "TEXT") (cons 40 (getvar "TEXTSIZE"))
                       (cons 1 txt) (cons 10 p) (cons 72 1) (cons 73 1) (cons 11 p))))
      (while
          (setq ent (car (entsel "\nSelect 3D-Polyline: ")))
          (cond (  (eq 'ENAME (type ent))
                   (if (eq "POLYLINE" (cdr (assoc 0 (entget ent))))
                     (if (and (not (eq 8 (logand 8 (cdr (assoc 70 (entget ent))))))
                                   (eq 4 (logand 4 (cdr (assoc 70 (entget ent))))))
                       (princ "\n** Object Must not have Arc Vertices **")
                         (setq i (1- (vlax-curve-getStartParam ent)))
                         (while (<= (setq i (1+ i)) (vlax-curve-getEndParam ent))
                           (setq pt  (vlax-curve-getPointatParam ent i)
                                 dif (cond (  (eq (vlax-curve-getStartParam ent) i)
                                              (setq t2 (-  (caddr pt) (caddr (vlax-curve-getPointatParam ent (+ i 0.5)))))
                                              (if (not (zerop t2)) t2))
                                           (  (eq (vlax-curve-getEndParam ent) i)
                                              (setq t2 (-  (caddr pt) (caddr (vlax-curve-getPointatParam ent (- i 0.5)))))
                                           (t (setq t1 (-  (caddr pt) (caddr (vlax-curve-getPointatParam ent (+ i 0.5))))
                                              (if (not (or (zerop t2) (minusp (/ t1 t2)))) t2))))
                           (if dif
                             (mk_pt (vlax-curve-getPointatParam ent i)
                                    (if (minusp dif) "LP" "HP"))))  t))
                     (princ "\n** Object Must be a 3D-Polyline **"))))))
      (princ))
    Hope this helps,
    Lee
    Lee Mac Programming
    Just another Swamper
  8. #8
    Senior Member
    Sep 2006
    334
    Lee Mac, that was an awsome bit of clever programming there. 10/10
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,718
    Thanks Iain
    Lee Mac Programming
  1. reduce No. of points
    By barba in forum AutoCAD General
    Last Post: 9th Sep 2011, 08:30 pm
  2. Graphing points, scaling the points
    By live4soccer7 in forum AutoCAD General
    Last Post: 25th Jul 2008, 09:44 pm
  3. put points on an arc every 6'?
    By p0026376 in forum AutoCAD Beginners' Area
    Last Post: 11th Aug 2007, 02:31 pm
  4. points
    By yiyan in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2007, 02:12 pm
  5. points in 3d
    By yiyan in forum AutoCAD General
    Last Post: 16th Jan 2007, 02:43 am
