Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Xref
    Full Member
    not applicable
    May 2005
    79
    Default Xref
    Hi,
    I have a drawing that has a Xref map drawing attached to it. Is there a way in AutoCad LT to make it part of the drawing so that I can explode and manipulate it?
    Thanks
    EBJ
    Senior Member Methuselah's Avatar
    Methuselah's Computer Details
    XP x64
    Mechanical
    Methuselah's Discipline Details
    HVAC Designer, BIM Technician
    Mechanical
    Revit MEP 2012
    Sep 2005
    Oklahoma City, OK
    284
    The whole point of xrefs is to have one part or drawing that can be inserted into a number of other drawings and can update those drawings if you happen to change the xref drawing. I know that sounds a bit too wordy, but I don't know another way of explaining it.
    If you want to edit an xref without updating all the drawings that contain that xref, just insert the xref as a block using the "insert" command.
    If you want to edit the xref and let it update all the drawings that use it, just go to the original drawing and edit that then save it.
    If you don't have access to the drawing used as the xref, you can "bind" the xref and make it part of your current drawing.
    To do this:
    1. Click Modify menu-> Object-> External Reference-> Bind.
    2. In the Xbind dialog box, click the plus (+) sign next to an external reference.
    3. The five types of named object definitions (Block, Dimstyle, Layer, Linetype, and Textstyle) are listed.
    4. Click the plus (+) sign of one of the definition types. The names of the definition table entries are listed.
    5. Select a named object definition. Click Add.
    The named object definition is listed under Definitions to Bind.
    If necessary, repeat steps 3 and 4.
    Click OK.
    Senior Member
    AutoCAD 2009
    Sep 2005
    Fort Lauderdale, FL.
    265
    it has all been said.
    XP x64
    Mechanical
    Mechanical
    Revit MEP 2012
    Sep 2005
    Oklahoma City, OK
    284
    Quote Originally Posted by Bloodwig80
    Bloodwig, you don't seem to explain things very well... :ermm:
    If it has all been said, show us where...
  5. #5
    Senior Member
    AutoCAD 2009
    Sep 2005
    265
    it was all said on post #2 in the current thread.
  6. #6
    XP x64
    Mechanical
    Mechanical
    Revit MEP 2012
    Sep 2005
    Oklahoma City, OK
    284
    Oh well, ok then!
    I guess I misunderstood ya, then...
  7. #7
    Senior Member
    not specified
    Sep 2005
    Kent, UK
    156
    bloodwigs just trying to increase his postcount, his nearly at 100, and we all now about the nervous 90's in cricket
  8. #8
    XP x64
    Mechanical
    Mechanical
    Revit MEP 2012
    Sep 2005
    Oklahoma City, OK
    284
    I live in the U.S. and we don't play cricket here. In fact the only time I've ever seen or heard of cricket was when Casey Jones used a cricket stick to smack Raphael upside the head in Teenage Mutant Ninja Turtles the movie!
  9. #9
    Senior Member
    not specified
    Sep 2005
    Kent, UK
    156
    well in cricket u score runs, like baseball, but you get lots of turns until your out and when you get into the 90s you want to reach 100 as quickly as possible as its like a landmark. and a lot of batsmen get nervous because they could get out before they get there
  10. #10
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    Winston-Salem, NC - USA
    4,455
    Quote Originally Posted by tommy
    Ah, I guess like say a 52-game hitting streak
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
