Results 1 to 2 of 2
    Forum Newbie
    not applicable
    Dec 2009
    1
    Default 3D model of bubbles inside a liquid/ random object postions
    Hi, I want to model what bubbles in a liquid will look like for exporting into a electromagnetic simulation. To do this I want to model the bubbles as small spheres having same size which have a random locations. I will need several of these bubbles. I can use a random number generator to generate the location but my question is how do I get autocad to create the bubbles at the locations generated by these random number generator?
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Welcome in the forum, Mideoguns!
    So, you already have a random number generator, right? Can it export data in a text file?
    If so, you can create a script file to create spheres considering groups of 3 numbers as coords.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  3. Have a problem for Sheet Set Manager users relating to Callout bubbles
    By charlie72 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2008, 10:45 am
  4. want to project all 3d model object on 2d plane.
    By ybborhade in forum AutoCAD Drawing Management & Output
    Last Post: 28th Nov 2007, 08:49 am
  5. engrave text inside a ring object?
    By erona in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Feb 2005, 02:06 am
