ziemerd Posted December 2, 2009 Share Posted December 2, 2009 I thought if I made a block on the 0 layer that I could insert it and place it on any layer I want. I can insert it and put it on a layer then turn that layer off but the block does not disappear. Any ideas? Thanks Dawn Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 2, 2009 Share Posted December 2, 2009 Yes. You created it incorrectly. Try again. It works for me 100% of the time no matter if I turn the layer off or freeze it. Quote Link to comment Share on other sites More sharing options...
ziemerd Posted December 2, 2009 Author Share Posted December 2, 2009 I made sure the objects for the blocks were on layer 0. Then I made the blocks while layer was on Layer 0. I inserted the blocks on my drawing and put on on the Part layer and the other on the Cutout layer. I turned off the Part layer and my block does not go away. So then I went to the paper space tab this drawing is on and froze the layer and it worked. Why can't I get it to work in model space? The most important thing is that the block disappears when I freeze the layer in the viewport so I'm ok but I still think it should work in model space. Thanks. Dawn Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 2, 2009 Share Posted December 2, 2009 I can't see why AutoDesk Electrical would work any different than plain AutoCAD when it comes to the creation and use of blocks. Quote Link to comment Share on other sites More sharing options...
dbroada Posted December 2, 2009 Share Posted December 2, 2009 I'm now using 2008 Electrical and it works as Mark & I expect. Can you post your problem block? Quote Link to comment Share on other sites More sharing options...
Glen Smith Posted December 2, 2009 Share Posted December 2, 2009 ziemerd, Just to check, are you talking about BLOCKS or Components? Blocks behave the same way as we would expect in other versions of CAD, but I have recently noticed (as I try to get us using Electrical as Electrical rather than expensive CAD) that components appear to behave differently. I have a component with an attribute on a SIGNAGE layer. If the door gets a number different from the room number, it goes there. I can insert the component and WATCH the attribute come in on the right layer (color light blue) and then change to the MISC layer (color white). I've not had time to play with it, but there are definetly some odd behaviors regarding layers here. Glen Quote Link to comment Share on other sites More sharing options...
ziemerd Posted December 4, 2009 Author Share Posted December 4, 2009 I've noticed a lot of quirky things with electrical versus plain AutoCAD. I just work through them the best I can. Sorry Dave, I've moved on since this problem and am unable to post it. Thanks for the help everyone. Dawn Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 4, 2009 Share Posted December 4, 2009 Care to share a little more with us? You "moved on"? Does that mean you just ignore the problem? Quote Link to comment Share on other sites More sharing options...
ziemerd Posted December 4, 2009 Author Share Posted December 4, 2009 What I need to show up does show up in the viewport and the same with what I need to NOT show up when I freeze layers. In model space the block does not disappear when the layer is turned off. I've moved on since it works in the viewport and that's what's important. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 4, 2009 Share Posted December 4, 2009 You're right. That's all that counts. Thanks for updating us. Quote Link to comment Share on other sites More sharing options...
