marcs Posted December 2, 2009 Share Posted December 2, 2009 Hi! I've got several drawings with room numbers indicated with text. What I need to do is inserting a standard block at each insertion point of these text objects. The block contains attributes which tag is NUM. As an extra: Ideally, the attribute value should be equal to the old text value. I thought this could be done using a field, maybe. Can anyone help? Thanks Marc:cry: Quote Link to comment Share on other sites More sharing options...
SteveK Posted December 3, 2009 Share Posted December 3, 2009 I don't know a way without Lisp, but if you ask this question in the Autolisp forum you'll get an answer. Quote Link to comment Share on other sites More sharing options...
