Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Junior Member
    AutoCAD 2009
    Dec 2009
    17
    Default title block setup
    Can someone help me with title block? I have a temp title block dwg and I use it for my 24X36 temp dwgs. Now I want to use that same temp title block dwg for 11X17. For some reason the temp title block is not on the sheet (paper space) when you preview before plotting (scale set to 1:1).
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Quote Originally Posted by jcreech View Post
    What layer is the TB on? Is it set to not plot in the layer manager?
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Junior Member
    AutoCAD 2009
    Dec 2009
    17
    Everything plots ok. But it cuts off some of my title block.
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Your scale is 1:1 and the title block is not fully plotted. That means that the TB is too big for the plotting area. Reduce the TB down taking into account the margin most plotters need.
  5. #5
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2014
    Dec 2008
    Rancho Cordova, CA
    541
    Are you using window for your plotting area? Maybe the window needs to be adjusted.
    Calvin
    Soli Deo Gloria
  6. #6
    Senior Member mrbucket's Avatar
    mrbucket's Computer Details
    Windows 7 Ultimate
    Antec 9Hundred
    ASRock A780GXE 128M
    AMD Phenom Quad 9950@3.0ghz
    4 Gigs OCZ Dominator@1333, 4 Gigs Flash Mem L3 Cache
    Radeon 8670 HD 1 gig
    Seagate Barracuda 500 Gig 16 mb Cache
    22" Sceptre HD
    Architecture 2010
    Aug 2007
    Brick, N.J. USA
    271
    Did you just copy and paste onto the 11x17 area? You will have to adjust the new tb to accomodate a much larger d size sheet. Scaling wont work either, it will change your text and line scale.
    My ESC key is worn out.
  7. #7
    Junior Member
    AutoCAD 2009
    Dec 2009
    17
    Do you know what is the TB 11x17 size is in paper space?
    Thanks, JC
  8. #8
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Start with 10x16 and adjust until you find the exact size that works or you can live with.
  9. #9
    Windows 7 Ultimate
    Antec 9Hundred
    ASRock A780GXE 128M
    22" Sceptre HD
    Architecture 2010
    Aug 2007
    Brick, N.J. USA
    271
    Just out of curiosity- What is the advantage of having titleblocks in model space and not set-up in paperspace with default template?
  10. #10
    Junior Member
    AutoCAD 2009
    Dec 2009
    17
    because if you have multi. drawing in model space, you have to window each time you want to plot. If you use paperspace all you have to do is click on tab and plot.
  1. Replies: 4
    Last Post: 17th Oct 2009, 03:21 am
  2. Title Block and .dwt
    By edgley in forum AutoCAD Beginners' Area
    Last Post: 26th Oct 2007, 11:01 pm
  3. More Title Block ???
    By wastewater in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2007, 09:45 pm
  4. title block help please
    By kunal in forum AutoCAD General
    Last Post: 3rd Jan 2007, 11:36 am
  5. Title Block
    By Cadgirl10 in forum AutoCAD Beginners' Area
    Last Post: 26th Jun 2006, 02:53 pm
